My New Warco VMC Turret Mill
Home Forums General Questions My New Warco VMC Turret Mill
Viewing 20 posts - 26 through 45 (of 45 total)
  • #102451
    Mustafa B. Adday
      @mustafab-adday34743
      Posted by chris j on 01/11/2012 10:12:44:
      I got a message that someone had posted that they were having trouble seeing the pics.
      I wonder what happened to that post ?
      I have now worked out how to rotate them, sorry but here are the correct ones.
      Yes Chrisj, I'm wondering also…
      Regards, Mustafa
      chris j
        @chrisj
        Fitted the DRO's and mucked about all day setting up and tightening things.
        Then I made loads of swarf !!
        What a lovely piece of kit.
        Despite the couple of problems overall I am so pleased.
        #103458
        Nealeb
          @nealeb
          Not sure when you ordered your VMC, Chris – I ordered mine back at the Warco open day in August and it arrived on Friday (early Nov). I was told that they were waiting for a delivery and then had to wait for a workshop slot to fit the DRO and power feed. I was also told that I would get 24hrs notice from the courier firm – does a call saying "I'm just getting to the end of your lane – where are you exactly?" count? However, the delivery driver was very used to Devon lanes and difficult access, and seemed to regard it as a personal challenge to deliver! So 50 yards on his pallet truck with my wife and I assisting was just par for the course – including half that being up a 1 in 7 drive…
          So, with pallet in garage, it was up to me to unpack and install. I wouldn't necessarily recommend it, but I did the whole thing single-handed except for one small area where a second pair of hands was useful. I was also limited by headroom – ceiling height is only about 2m, and slightly less where an RSJ crosses. With the aid of levers and rollers (posh word for broomsticks) I was able to move the pallet to where the machine was going. I then removed the motor, then head, then turret, in that order. The head assembly was heavy but just possible by myself, while the machine was still off its stand. Note that you do have to disconnect the motor wires (labelled wires going to labelled connections, which was good, but a picture on the mobile phone was useful as a cross-check) and belt guard microswitch (fiddly). The Warco manual says that you should not use the hoisting point for lifting as it the machine is top-heavy. However, I found that with the top end removed this point works fine. I slipped a bar through the hoist point holes, and the winch hook then went through the top of the column. When lifted the machine tilted forwards a little, so that the front of the base was about 2" lower than the back. To lift, I built a rough-and-ready gantry with a couple of 4×2 verticals well-clamped to the legs of two stout benches which were already in place either side of the planned location. I used another 4×2 across the top, located with 4" nails hammered into the end-grain of the verticals. The winch was a cheap ratchet thing, picked up for £15 from a local market stall and generally used for pulling out tree roots. Nominal rating 2T, which should have been fine for the approx 350Kg or so of the VMC without base or top end. So, lifted the mill a little, dragged out the pallet, lifted a bit more when I was happy that nothing was bending too much and slipped the base underneath. This was the bit that needed a second pair of hands – my wife was able to nudge the mill around slightly as I lowered so that the bolts lined up. So far so good. Then turret back on, motor fitted, and the only really tricky bit – getting the spindle assembly in position. This was now much too heavy for me to lift and position with the mill on its stand, so I improvised with ropes from the gantry until I could get the spindle nose resting on a wooden block on the bed. With rope slings taking most of the weight I could use the bed to position the spindle mating face and its bolts fairly easily. Rewire, and ready to go. It would have been easier with a couple more pairs of strong hands but I am new enough to this house not to feel comfortable in inviting neighbours to a hernia party.
          Initial comments on the VMC. I mentioned the mill-to-stand bolts above. Unfortunately the holes do not all line up (are these drilled freehand in the factory?) and I can only get two diagonal bolts into the tapped holes in the base. I plan to drill out the other holes and if necessary will use nuts on the bolts to hold it all in place. Annoying, but I'm not going through that again to replace the stand…
          When I put the feed handles on, the power feed did not work. The motor was going round but nothing else did. I suspect that the bevel gear on the leadscrew had slipped out of engagement in transit and I did not check when I put the handwheel on. I removed the handwheel, had a fiddle with the other components, and when I put it back together it worked fine. Problem here was lack of instructions in either of the manuals so it's something to watch out for.
          DRO had not been tested, judging from the packing on all the bits, and needed setting up as per its manual to get all the slides working the right way (numbers on dial going up while numbers on DRO going down would have rapidly driven me crazy!)
          If I had been a complete numpty, any or all of these things would have stumped me. For example, then manual says that you can strip off motor and head to help installation, but doesn't say how. But none of this should stop a competent model engineer – there's no rocket science needed here, just a steady and methodical approach – and nothing to put off any other prospective VMC buyer. I'm now looking forward to cutting metal – once I have fixed those hold-down bolts…
          Edited By Nealeb on 12/11/2012 12:00:39
          Edited By Nealeb on 12/11/2012 12:03:50
          #103461
          Roger Vane
            @rogervane67137
            Hi Nealeb
            I had problems with the holding down bolt positions with my VMC – Warco had sent me the wrong stand where the bolt positions were different – obviously a case of different machines, different stands. They changed the stand within a couple of days and I had no further problems. Might be worth talking to Warco before you drill the new holes.
            #103476
            Nealeb
              @nealeb
              Thanks for the comments, Roger. I'm pretty sure that it is the right stand, but the clearance holes in the machine base are fairly tight for the bolts, and the two "wrong" tapped holes in the stand are only out by about 2mm. I can't believe that there are two machines with that close a spacing. If it were 10mm or more then "wrong stand" would probably be the right diagnosis. And I just want to get on with using itsmiley
              #103477
              Roger Vane
                @rogervane67137
                The holes in my stand / VMC base were much further out than 2mm, so I guess that you've got the correct stand badly made.
                #103478
                chris j
                  @chrisj
                  I pleased to say that my stand & mill fitted well together.
                  I think the VMC is a good mill despite all these problems that are reported.
                  I feel that Warren Tools do not do enough work around the edges of selling these machines.
                  So many of the problems that I have encountered could be sorted easily with a bit of care.
                  By that I mean installation guides, maybe some on-line videos. All very cheap to produce.
                  The delivery service needs sharpening up for sure.
                  I have a pal who warned me that Warren Machine Tools only seem interested until you have paid your money and after that….
                  I'm not sure I would go that far but instead of a warm glow I am feeling a little dissapointed.
                  #103492
                  Brian O’Connor
                    @brianoconnor49474
                    Chris,
                    If you haven't discovered it already, Grizzly in the States produce an excellent downloadable manual for the G3102/G3103 Mill, which is their version of the VMC. It's far better than the thing that Warco produce. The only part of it which is not applicable is the section dealing with the electrics.
                    #103493
                    chris j
                      @chrisj
                      Posted by Brian O'Connor on 12/11/2012 17:53:45:
                      Chris,
                      Now that is a good tip, thanks
                      #103498
                      Nealeb
                        @nealeb
                        …and I'm not sure that the Warco manual circuit diagram ties up with the current switchgear. However, there is a circuit diagram behind the panel on the back of the column which I presume is correct.
                        I drilled out those other two holes this afternoon – just put a 10mm drill through them – and fitted bolts with nuts beneath. All now firmly secured.
                        #103499
                        chris j
                          @chrisj
                          Posted by Nealeb on 12/11/2012 19:14:58:
                          Neal
                          Did you get the suds pump ?
                          I did but I'm not having the easiest time of things.
                          #103510
                          Nealeb
                            @nealeb
                            No, I didn't – I did get the extra big drip tray because I intend to get a suds pump one day but didn't actually spring for it. My previous vertical mill was the Dore-Westbury, and that is hardly big enough to warrant coolant so I wasn't sure how useful/necessary it would be.
                            What's your problem with it? I would have expected it to be straightforward on a single-phase supply – or is it 110V like the power feed? Is it wired off the mill circuitry, or does it have its own power? Or is it the plumbing rather than the wiggly amps that's giving problems?
                            #103514
                            chris j
                              @chrisj
                              It works well enough but the fluid settles in every nook and cranny of the machine rather than go back to the reservoir.
                              I am going to need to drill a few drain holes and make some modifications I think.
                              #103558
                              Nealeb
                                @nealeb
                                I did notice that the drain in the base sticks up quite a way, and the left-hand end of the table does not have a drain at all. And there's a nice lip around the base of the mill that will hold a reasonable amount of fluid… Does the suds also drain down through the raised edges front and back of the machine base into the cabinet?
                                When I was in the US some years back a number of model engineering friends had mist lubrication/cooling systems – they used compressed air to atomise water and spray it on to the cutter. It evaporated almost immediately, so no rust, no drainage, no mess, but did seem to keep the cutter cool. Of course, they assumed that everyone would have a compressor and an airline around the "shop"!
                                #103560
                                chris j
                                  @chrisj
                                  Also ran a hose from the table rhs down to the reservoir.
                                  Also I've drilled 2 small holes in the back of the base so the fluid can escape.
                                  Getting over the lip in the tray may require a gutter system under the tray and a few holes drilled.
                                  How do others cope I wonder.
                                  Like the idea of the atomiser.
                                  #103581
                                  Bazyle
                                    @bazyle
                                    Check the other threads about cutting fluid for various views.
                                    I did wonder if you were going to seal the edge of the base to stop it leaking down the bolt holes as there was no mention of a gasket in the install reports.
                                    #103586
                                    chris j
                                      @chrisj
                                      Posted by Bazyle on 13/11/2012 16:31:37:
                                      Oh yes I did read a post where it was recomended and so I did it.
                                      I forgot to mention that smiley
                                      Do you think there is mention of a vms's particular cutting fluid problems ?
                                      Chris
                                      #103602
                                      Sub Mandrel
                                        @submandrel
                                        HI Chris,
                                        Glad it's ahappy ending!
                                        Bazyle: "Take precautions for a tip-over though which is one reason I wouldn't recommend assistants under fifty. Old guys aren't in such a hurry."
                                        Does that mean I have four days left to live fast and die young?
                                        Windy
                                          @windy30762
                                          I bought the same mill over a year ago and the first thing to hit me was that the bolt holes on the base to stand were very close to the edge on the front edge then the fine power feed was on and off.
                                          Warco sent a new potentometer plus other parts that were faulty promptly.
                                          In these days of health and safety as regards electrics I had to strip and replace the potentometer myself.
                                          As regards moving and assembling it as a 70year old and not that fit with a home made engine hoist, limited head room and on a slope with common sense and suitable straps it was assembled and moved into position one handed.
                                          As my old friend used to say there is no word as can't join the try company.
                                          Windy
                                          Edited By Windy on 14/11/2012 00:50:54
                                          #126718
                                          kevin simmonds
                                            @kevinsimmonds92469
                                            Hi I recently purchased a second hand Warco VMC which was manufactured in 2011. I removed the head/Motor for transportation but unfortunately lost the piece of paper with wiring connections on. The motor is a single phase double capacition induction motor.
                                            The terminal block inside has on the top row left to right connections
                                            Z2/W2 next U2 next V2
                                            bottom row lower left U1 next V1 next Z1/W1
                                            The wiring to the motor has the following labels attached.
                                            Red wire Z1 Red wire Z2 Black wire n11 Black wire L11 and an earth wire which has an obvious position on the motor.
                                            I contacted Warco and they sent me a circuit diagram it had no reference to the connection on the motor. Can anyone help????
