Here's my solution and it works a treat:
One VFD to power both the drilling machine and shaper and another for the two milling machines, each in their own enclosure situated between respective machines.
Power from the VFDs is wired up to triple pole centre off selector switches housed in each enclosure, thus allowing me to easy select which machine to sent power to, BUT only after switching off at the wall socket, and most definately NEVER whilst a machine is running.
The VFDs are calibrated for the most powerful motor of the two.
Cannot, of course, run both machines at the same time, but wouldn't want to.
Once you've used machines with VFD power, you never look back!
Only the lathe has a dedicated VFD.
Geoff – Belt/pulley changing now history, just know knob twirling. Heaven
