motor brushes ?
motor brushes ?
Home Forums General Questions motor brushes ?
Viewing 8 posts - 26 through 33 (of 33 total)
  • #119025
    John 77
      @john77
      From my experience in 25 years in electrical maintenance. I have made small brushes from lager ones
      I always used a file as emery paper dose leave particals in the carbon, there are different types of brushes some are plain carbon / carbon graphite / carbon graphite copper mixes if you use the wrong type you will get commutator ware Plain carbon are the most abrasive and the graphite type are the less abrasive. If you look at the original brushies you can get a good idea what type you need.
      John 77
        @john77
        Hopper
          @hopper
          You can sometimes use the old dogde of putting a little piece of something on top of the old brush, between the brush and spring. Increases the spring tension and pushes the remaining carbon against the commutator.
          A piece torn from a matchbox and folded up was the traditional roadside fix on DC motorcycle generators etc.
          #119035
          Hopper
            @hopper
            #119054
            Hopper
              @hopper
              #119082
              Ian S C
                @iansc
                There are about as many grades of carbon brushes as there are motors to fit them to. One of my (old) books "Practial Design of Small Motors and Transformers" Edited by E. Molloy, 6th ed 1947 quotes 23 different grades, it depends on voltage, AC or DC, high or low voltage, and motor speed. It also depends on whether the mica is flush, or recessed. Back then a high speed motor was 10,000rpm, I'm sure its a bit higher on todays tools. Ian S C
                #119099
                Ian S C
                  @iansc
                  #119115
                  Ian S C
                    @iansc
