Mk. 2 Progress Model 1 bench drill.
Home › Forums › Manual machine tools › Mk. 2 Progress Model 1 bench drill.
  • #548943
    Rod Ashton
      @rodashton53132
      Gentlemen. I am refurbing a Mk. 2 Progress Model 1 bench drill.
      It has the MT No. 1 taper and No. 6J nose for the chuck. In the spindle there is a drift slot and a knurled threaded ring under that. Is this ring for locking down on something, or for bearing down on the chuck for removal. The arbor tang does not extend into the drift slot? How then to remove the arbor and chuck please?
      Do not have double wedge set. If that is the method. But could make.
      #14283
      Rod Ashton
        @rodashton53132
        Refurbishment
        #548952
        Brian Wood
          @brianwood45127
          Hello Rod,
          You are correct in your assessment, the ring is used to push off the chuck when fitted to the Jacob taper
          I would extend the arbour tang so that you can use a drift to separate the Morse tapers
          My drill is the New Progress #1 which only has the knurled ring for chuck release
          #548960
          Rod Ashton
            @rodashton53132
            Brian – Thanks for info.
