Looks like a useful machine. The tapered bearings in your pic would be bronze. They are similar to the ones in my M type. It looks as though on your model you pull the tapered bearing into its tapered hole by tightening the two screws on the end plate . The trick is, to slacken off those two screws on the top of the headstock casting first. You then tighten the the bearings up until some drag is felt. Then when you retighten those two screws on the top, they expand the outside of the tapered bearing outwards into firm contact with the tapered hole in the headstock casting. This creates a bit of extra clearance on the shaft so it can take several tries to get the clearance just right, ie no drag, no shake (ideally!). Not sure with this model, but you may have to slacken the screws on the round retaining plate on the other end of teh bearing to allow it to move longitudinally in that direction as it is tightened up.
There is an info sheet on adjusting M type bearings in the Yahoo Drummondlathe group File section. Not sure if there is one specific to the B flatbed like yours but the principal is the same.
I can't see in the pics but I think those two screws sticking up on the top of teh headstock casting, one at each bearing, should have a small hole drilled down the middle of it to allow you to oil the bearings with an oil can as you work. Many owners solder on fittings to each screw to allow a drip feed sight oiler to be fitted, a la later Myfrods.
You could replace that dangerous looking V belt (which has probably run for decades without blinding anyone but who wants to be the first?) with a link V belt from the usual Myford suppliers. It can be fitted and joined up without having to remove the headstock spindle.
Your missing change gears, which would be the same as the more common Drummond M-Type's, would only be needed for screwcutting threads. Ordinary turning feed is normally effected by hand cranking the handle on the right-hand end of the leadscrew,
Edited By Hopper on 01/01/2017 12:20:51
Edited By Hopper on 01/01/2017 12:25:09
