Minnie Traction Engine – Steam Block
Home › Forums › Beginners questions › Minnie Traction Engine – Steam Block
  • #378819
    Malcolm Farrant
      @malcolmfarrant93389
      I have at last completed, I think my boiler
      Now moving forward I am confused by the Steam Block. The 7/32 front hole is for the connection for the Water Gauge.
      That leaves a 5/32 and a 7/32 threaded female entry.. One of these is I presume for the Pressure Gauge (shown as being 3/8th Diameter. Which One ? and what is the other for.
      Please could someone enlighten me
      #9394
      Malcolm Farrant
        #378823
          The other one is for putting a plug in as it is not used!
          Top outlet for pressure gauge though my drawing shows it as 3/16 x 40 which takes short threaded nipple for a 3/32" pipe nut to go onto for the gauge pipework.
          #378972
          Malcolm Farrant
            Yet again, Thank you JasonB.
            You are correct, The measurement is 3/16th x 40.
            Would it be safe to put in a plug in the blank hole and then soft soldrf it ?
            Malcolm
