Milling M/C
Milling M/C
Home › Forums › Beginners questions › Milling M/C
  • #166393
    Jack Foreman 1
      @jackforeman1
      Has anyone any thoughts on Tom Senior Milling Machines (M1)
      Either an Elliott Omni or a Tom Senior will be ideal from a 'space available point of view'. Perhaps not the most efficient criteria for selecting a mill, but nevertheless….. emotion
      #7334
      Jack Foreman 1
        @jackforeman1
        #166396
        Phil Whitley
          @philwhitley94135
          My friend Jim has just got an M1, and it is the first Tom Senior I had seen, I was very impressed with the quality and build is solid! Have a look on http://www.lathes.co.uk, on the machine tool reference guide, he gives all the details. Nothing wron with Elliot either, top quality machines, nothing to choose between really, depends on what you can get!
          Phil
          #166397
          Phil Whitley
            @philwhitley94135
            There is also a Tom Senior Yahoo group with lots of info, and some very knowlegable members too.
            Phil
            #166401
            Jack Foreman 1
              @jackforeman1
              Thanks Phil. I've read the lathes.co.uk material. Quite comprehensive, isn't it?
              #166402
              Bazyle
                @bazyle
                The Centec 2B is about the same size too. And the Warco VMC (and Chester equivalent) which is basically a copy of the Elliott.
                #166403
                Nick_G
                  @nick_g
                  The Tom senior was also on my 'looking list'. But like you space is a consideration.
                  I decided it would be a little tight in the area the mill needs to go. I could fit it in but then would not be able to store my motorbike also. sad
                  I take delivery this week of a Boxford VM30 which is not quite as large but also does not have some of the features that a Tom senior does.
                  If you get a good one that has been looked after I hear Tom seniors are 1st rate in the application the were designed for.
                  Nick
                  #166405
                  Saxalby
                    @saxalby
                    I've had my M1 with the "S" type vertical head, for 20 years or so. Very solid and well built. I have updated it by fitting a three axis DRO's, and an inverter drive on the vertical head.
                    Very happy with whats its capable off, and would be reluctant to ever sell it.
                    Barry
                    #166484
                    Jon
                      @jon
                      Jack if you can find a good one with a vertical head snap it up.
                      Fairly robust for a small mill but do stand out from a wall. Will need extra room at back if using the horizontal mill on ISO taper.
                      Only used the one where used to work on occasions, load up and leave to run, theyre ok. In fact far better than the 626, VMC and the like, they were made to last. Ronan picked one up last year and quite happy.
                      Most have seen are worn, walk away and bide your time.
                      #166488
                      Jack Foreman 1
                        @jackforeman1
                        Posted by Nick_G on 12/10/2014 21:31:35:
                        I take delivery this week of a Boxford VM30 which is not quite as large …..
                        Nick
                        That is a smart looking mill Nick. I have room for a Senior, but not the headroom for Bridgeport.
                        My wife thinks I'm spending my money on wood-turning stock & blanks.
                        When I die i only hope that she doesn't sell all of my machines for what she thinks i paid for them. embarrassed
                        #166489
                        Jack Foreman 1
                          @jackforeman1
                          Posted by Saxalby on 12/10/2014 22:47:51:
                          Barry
                          What would be the requirement to assist you in reversing that reluctance Barry??? emotion
                          #166511
                          Saxalby
                            @saxalby
                            You wil have to prise it from my cold dead hands.
                            That, or lots of folding money.
                            Barry
                            #166545
                            Nigel McBurney 1
                              @nigelmcburney1
                              I used to have a Tom Senior M1 mill with the standard vertical head,good well built solid machine,good for horizontal milling,unfortunately there is not much room under the vertical head,especially if Clarkson auto lock chuck is used, it would be ok if the E type head was fitted,lot more room and has a quill feed on the spindle though these are rare,though they do come up occasionally on E bay. you need room at the back to change belt speeds and remove the draw bolt for the horizontal arbour. Went to the factory once back in the seventies with a mate who collected his new E type mill,very good machine tool builders.
                              The Elliot omnimill looks ok plenty of room under the spindle though probably not so rigid as a Senior, Have a look at a Harrison,similar in size to the Senior though there appears to be more room under the spindle as the vertical head attachment is set higher in relation to the horizontal spindle, Some types of Senior and Harrison were supplied only as vertical,its far better to have the horizontal and vertical options. These mills are ok for small model building,i.e. 2'' traction engines,and 5'' locos,but if you may want to restore old motor cycles or stationary engines then a bigger mill is better i.e. Bridgeport as you always run out of room on a smaller mill.though a smaller mill is far better than no mill.
                              #166546
                              Jack Foreman 1
                                @jackforeman1
                                Posted by Saxalby on 14/10/2014 09:33:00:
                                Barry
                                I thought that might be the case sad Good for you. Hang onto what is precious to you.
                                I never really imagined that you may be persuaded, & may your cold dead hands be many, many years away. emotion
                                ATB
                                Jack
                                #166549
                                Jack Foreman 1
                                  @jackforeman1
                                  Thank you Nigel. That is very sound practical advice. And very much appreciated.
                                  I'll do some research into the Harrison.
                                  I honestly can't profess to be a model engineer – and it is extremely unlikely that I will ever build a loco. But it is equally unlikely that I will ever restore a motorcycle or a car. Much of what I am doing and intend to do, in the foreseeable future, is to make items for my wood lathe, picture framing work and tool/application items around the workshop.
                                  I am looking at a school Senior, which appears to be in very good condition, as would be expected. I will go back and check on the dimensional issues you have raised.
                                  Kind regards,
                                  Jack
                                  #166571
                                  Brian Wood
                                    @brianwood45127
                                    Hello Jack,
                                    My own experience is with the Junior model I picked up at auction over 10 years ago. Like the comments made on MI machines, it is beautifully made and as accurate a machine as I need. I had to break into the motor windings to make it reversible, the motor fitted was of non original Chinese make, but it runs well and will work all day without complaint
                                    It is a smaller machine maybe than what you are looking fior, but coming from the Senior stable I think it is a testament to the quality of their work.
                                    Regards Brian
