Milling cutter coding
Home Forums Beginners questions Milling cutter coding
  • #398653
    Bernard Greatrix
      @bernardgreatrix61453
      Hi All,
      I've just taken delivery of a new milling cutter with 4 flutes x 12mm diameter and I'm curious about the coding on the packaging :-
      12 x 12 x 26 x 8
      One of the 12's is the diameter – 12mm
      What is the 2nd 12
      26 is the length of the helix
      What is the 8 for
      Bernard
      Bernard Greatrix
        #398654
          The other 12 will be shank diameter
          Are you sure there is nothing missing off the end as around 80mm overall length would be right, have a look here for the 4 dimensions
          Edited By JasonB on 04/03/2019 15:44:59
          #398655
          not done it yet
            @notdoneityet
            Ask the vendor? The supplier should know! Then tell us all. I'm intrigued.
            #398666
            Bernard Greatrix
              Thanks Jason – your analysis was spot on. I didn't think about the shank diameter and the label was damaged just after the "8" so I made an assumption (I know, I know, I shouldn't do that)
              The ARC table tells all – I'll make a copy and keep it handy
              Many thanks
              Bernard
