Thanks very much for your thoughts, the consensus is that within the limitations of the machine it's probably adequate and doing nothing is the preferred option, I wholeheartedly agree. I drew deeply on the trigonometry of over 50 years ago and have calculated I would need a shim of 0.0012" to correct it, this is almost baking foil, and as Vic has pointed out might well make it worse. Leave well alone if your ahead is just plain sensible. Thanks for the help.
Martin
Edited By Martin Shaw 1 on 07/01/2019 11:54:42
