I too enjoyed this issue more than most (and I enjoy most issues).
Can I make a couple of (hopefully) constructive comments?
As a beginner I sometimes struggle with the context of a story. For example, I now know how to make a spring centre, but I have no idea why I would want one!
As another example, I can see how to make the lathe stop, but I'm not really sure what to do with it once it is made. Is it something I Could use with a power feed for example? I'm about to do some largish turning on my lathe which will need to use the power feed and want to stop at the same point as I turn down a 40mm bar (up to a point). Do I spot this by eye, or should I make something which cuts the motor at a certain point?
I rather suspect most of the readers will be much further ahead than me so probably don't need spoon-feeding so much but perhaps others have the same struggle.
I loved the centring a 4 jaw chuck story – I've kind of given up on mine due to not having a clue. and I found something helpful in pretty much all the articles.
More like this!
Iain
