Metre Maid
Metre Maid
Home › Forums › Locomotives › Metre Maid
  • #374698
    Trevor Simpkins
      @trevorsimpkins79244
      Hi, im looking for anyone selling used drawings for Metre Maid 5", any help gratefully received, cheers Trev.
      #1760
      Trevor Simpkins
        Drawings
        #375391
        Trevor Simpkins
          Surely someone has some for sale!
          #375395
            Put and add in the Wanted Adds down the left of the page
            #375398
            DMB
              @dmb
              Trevor,
              A now deceased friend built a Metre Maid a few years back, but I dont know what happened to his drawings. I assume that you are plannning to build it. The point of this message is that he had a boiler made professionally by Helen Verrall and he had the design amended to a large flange on the site of the safety valves in the original design. He put a large tubular steam dome on the flange with the safety valves on top and a regulator valve at the back with a pipe leading down to the usual regulator position on this design. He reckoned that he had made a big improvement to the design with a proper steam dome rather than relying on the raised fire-box. Loco works ok, was donated as a club loco to Worthing & DSME. HTH and good luck. Try looking on internet for list of drawing errors – there are error lists for many designs.
              John McNamara
                @johnmcnamara74883
                Hmm I did a double take on that title. Obviously not made in Queensland.
                Cheers
                #375456
                Trevor Simpkins
                  Thank you, I have put a ad on wanted about 2 weeks ago and still no luck ! Thanks John I will have a look, cheers Trev.
                  #375496
                    Posted by Trevor Simpkins on 11/10/2018 11:58:40:
                    I suspect the actual number of people on the forum who have made a Metre Maid is probably very small (compared to, say, Rob Roy), then knock off any who want to keep the plans as a reference/keepsake or whose plans are now in a bit of a state and it may take a while for some to turn up.
                    #375517
                    Steambuff
                      @steambuff
                      I believe Blackgate's have the drawings for sale
                    Home › Forums › Locomotives › Topics
