Not enough info.
Can you tell us what they are for. You can have vee splines, straight sided splines and involute splines.
Doesn't sound like vee spline or straight sided serrations as they are known as these are a full vee, i.e. no flat.
Straight sided splines as the name implies has straight sides and usually a rounded bottom equal to the diameter of the base circle.
Involute splines are basically internal stubby gear teeth with rounded sides.
Good news is these have been around for ages and plenty of info on them, tables etc.
Edited By John Stevenson on 22/04/2015 21:40:44
