Yep.
Geo. H. Thomas did the Retracting Toolholder.
Martin Cleeve did the Swing Clear one.
Tubal Cain did a stop system for Myfords, probably adaptable to others, that limited retraction via the cross slide handle giving essentially the same result.
SouthBends, and maybe Boxfords, along with some others are equipped to take a threading stop clamping to the cross slide ways setting both retraction via the handle and, somewhat crudely, threading depth.
They all get you to the same place in practice.
I decided to do without extra bits and learned the zero-2-zero method.
For some folk one considerable restriction of Martins original Swing Clear tool holder is that it completely replaces the normal tool post. Not compatible with four way blocks or QC systems although it can be revised to fit at the cost of considerable extra overhang. It would work well as part of the quick change (two slot?) block system I've been known to advocate.
Martin made his living with a seriously modified and upgunned Myford so threading and other jobs needing the swing clear holder were batch processes with many parts to do. Switching toolposts was of little consequence.
But if you only have one or two threads to do ….
I have just finished a batch of 6 threaded parts needing 5 tools for each. The swing clear would have been totally impractical for that job.
