Marking out / drilling holes in precisley the correct place !
Home Forums Beginners questions Marking out / drilling holes in precisley the correct place !
Viewing 14 posts - 26 through 39 (of 39 total)
  • #225874
    Nobby
      @nobby
      Having marked the job out. On a drill or mill you can line up the lines using a sticky pin running true in the drill chuck then center drill etc On the drill when lined up clamp in place then center drill On the mill job should already clamped down as you can move the tables and use the micrometer dials . this is for home shop not in the tool room
      Regards Nobby
      John Reese
        @johnreese12848
        I usually dial in my hole locations using the DRO. I spot drill, then drill an undersized hole. I use an endmill like a jig bore reamer to correct any drift of the hole, then drill to the finished size. If I am using a boring head to finish the hole, I skip the end mill.
        #225878
        julian atkins
          @julianatkins58923
          in miniature loco work, the only time i clamp the vice on the pillar drill is when drilling big holes in steel which is the coupling and big end conn rod holes. in every other case i let the vice float and the drill find the centre popped hole.
          this was what i was taught many moons ago by a toolmaker.
          cheers,
          julian
          #225880
          Tendor
            @tendor
            Here is a good book that covers the topic. Holes, Contours and Surfaces Richard F. Moore, 1955 Predates DROs etc. The second book at the link is also highly recommended.
            Danny M2Z
              @dannym2z
              Posted by Michael Walters on 17/02/2016 23:12:19:
              what you need sir, is an automatic center punch, use a standard punch to deepen them if you wish.
              Michael W
              How is that going to make the hole location more accurate?
              The method taught to me was to lightly slide a prick punch along one line until the intersection was reached (it will 'click' into position) and then gently tap the head of the punch. Inspect the depression and slip the tip of a sharp 90° punch into the hole (if all is square) and give it a tap to deepen the hole enough to give a drill bit a decent start.
              Actually, for really precise location over marked lines I sometimes use my "CentreCam' which was manufactured about 8 years ago from the MEW article – It's accurate to about 1 thou (pixel) and great for centering over pre-existing holes.
              * Danny M *
              #225882
              Neil Lickfold
                @neillickfold44316
                Years ago, in toolmaking, we had a bunch of drill and reamer guides. These took drill bushes and reamer bushes and were made to a nominal outside diameter. There centre spacing was set with length rods and trig. These were clamped into place and used on the drill press or mill, these were quite large for the clamp to be secured. We also used buttons, also spaced with length rods and trig. But a smaller hole was drilled and tapped, a small screw to hold in place, then an indicator to indicate the position. Lock the machine in place, then removed the button, and used a milling cutter as a drill/boring bar to remove the thread. Then drill to the size, another milling cutter used as a boring bar, then the reamer. We used this method until we had mills with digi readouts and of course a lot better quality mill.
                At home here I made some small buttons with a hole in them. I then made a tool to go into the drill chuck that sits over the button. I then clamp after the tool locates the part for me. Remove the button and drill ream etc
                Emgee
                  @emgee
                  Hi Danny M
                  Can you please post a picture of the "Centre Cam" tool ?
                  Emgee
                  #225900
                  MW
                    @mw27036
                    Posted by Danny M2Z on 18/02/2016 05:49:48:
                    Michael W
                    * Danny M *
                    Well, i found at college, that it was actually alot harder than you think to hit a small punch in an accurate manner using a hammer, so it would make it more accurate if you found that this was your problem too.
                    Btw, if you're worried about using a camera to find the position of scribed lines, more than likely marked out using a ruler, then maybe you shouldnt be scribing your lines at all.
                    Michael W
                    #225902
                    Roderick Jenkins
                      @roderickjenkins93242
                      Posted by Michael Walters on 18/02/2016 09:48:48:
                      Tubal Cain recommended using a little archimedes drill to find the intersection of the scribed lines and start the indent.
                      Rod
                      #225911
                      Danny M2Z
                        @dannym2z
                        Posted by Emgee on 18/02/2016 09:19:33:
                        Hi Danny M
                        Emgee
                        Here is a photo of my minilathe tailstock centre taken when I was calibrating my CentreCam a few years ago.
                        One had to rotate the spindle 180° and count the pixels to offset the centre of the webcam software.
                        Webcam distance was tweaked such that scribed lines 0.640" apart on a test piece were 640 pixels wide. I then made a block to set the height.
                        I shall set it up tomorrow and take a few more photos, it was a brilliant article.
                        Michael, my reference lines were marked out using a Mitutoyo height gauge on a surface plate. One of the first projects that I made as a student was a small brass headed hammer to tap small punches and stuff so no problemo.
                        'Scribe a Line' is actually one of my favourite topics in MEW and it is quite presumptious to assume that everybody uses a ruler, despite what you learned in college.
                        * Danny M *
                        Edited By Danny M2Z on 18/02/2016 11:24:29
                        #225925
                        Speedy Builder5
                          @speedybuilder5
                          have we all gone 'soft' ? As already mentioned, mark the holes out using rule, height gauge etc, dot or centre punch and if you want, scribe a square box around the outline of each hole, then use a sharp spot or centre drill before opening up progressively with sharp quality drills etc. The hole should fit inside the scribed square box. If your drills are not accurately sharpened, they will drill off centre and unfortunately some new drills are not accurately ground. There should be no need to resort to using the mill for co-ordinates. 20 or more years ago, many MEs didn't even possess a mill. This sort of stuff is the sort of thing apprentices had to learn before being released onto the shop floor, and for newcomers to our hobby, it is just something you have to learn and get better at. There is no substitute for practice before you have a go at an important and expensive piece of metal etc.
                          #225942
                          Anonymous
                            Posted by Speedy Builder5 on 18/02/2016 13:01:59:
                            No, I don't think so, we've just moved into the 21st century where marking out and centre popping is no longer a necessity.
                            #225943
                            Jon
                              @jon
                              Believe the OP stated used centre punch or the like and drilling off. Will have to settle for the bodgers way reliant on a ruler, centre punch with mark 1 eye ball.
                              Usually centre punching raises the edge often a burr. If holding freehand or even in a vice your limited to getting the angle right and hope it starts cutting where desired and correcting.
                              Mill and a dro straight in no centre drills etc just the drill used, get a feel for whats happening and look for deflection. Accurate to size drill undersize then open up, drill or reamer will self centre.
                              #226171
                              Andy Ash
                                @andyash24902
                                I'm surprised no-one has mentioned about the light.
                                My workshop is by no means bad for light, but I still find that the act of making an accurate centre punch to a scribed line depends greatly on the quality of the light.
                                By the time you have your hand over the top of the punch, it blocks the light and you can't see properly.
                                I simply have an automatic punch set to the weakest setting, with a sharp pointy end. I also have one of those cheap pencil style LED torches. I just use one in each hand, and it eliminates any doubt. The torch lives in the drawer with the punch.
                                Once you have the dot in the right place, as long as the point cone on your ordinary punch is nice and round, getting a big welt with the hammer on target will be no problem at all.
                                HTH
                                Edited By Andy Ash on 20/02/2016 10:28:51
