Makita 12volt drill
Makita 12volt drill
Home Forums Workshop Tools and Tooling Makita 12volt drill
  • #341960
    Speedy Builder5
      @speedybuilder5
      My Makita 12volt drill has lost its power. Bought a new battery, even used a different charger, but only 30% of power / speed available. Do I suspect the windings or the variable speed trigger unit ?
      BobH
      #18851
      Speedy Builder5
        @speedybuilder5
        Drill loosing power
        #341971
        Brian Sweeting 2
          @briansweeting2
          Probably the trigger unit.
          #341981
          daveb
            @daveb17630
            Not sure if it's the same but I have a spare trigger from a 9v Makita drill. Gratis, if it's any good to you send me a PM..
            #342003
            Hopper
              @hopper
              Brushes are quite often the first thing to wear out on electric drills. Could be worth checking.
              #342025
              Speedy Builder5
                @speedybuilder5
                Thanks for the offer Dave B, but mine is 12v. There is a 3 pin "package" at the rear of the motor (Thyristor ??) so I guess that the 9v trigger is slightly different to the 12v one. I couldn't get the trigger apart to see what was inside it. The motor smells a bit "motorery" as if its worked a bit too hard at one time – probably so as I built our house with it.
                BobH
                #342037
                John Rudd
                  @johnrudd16576
                  The thyristor is probably a mosfet, typically an IRF530…..from battery drills I've encountered..
                  If you can access the connections on the back of the motor, might be worth checking to see if its receiving the full battery volts…
                  Edited By John Rudd on 18/02/2018 08:46:27
