Making an engineers sliding bevel. Apprentice piece?
Home Forums Beginners questions Making an engineers sliding bevel. Apprentice piece?
  • #270472
    samuel heywood
      @samuelheywood23031
      I'd like to make a small sliding bevel.maybe with only a 2" or 3" long blade.
      ~ plenty of carpenters bevels for sale, engineers version seem a bit thin on the ground & a little larger than i'd really like.
      I suspect making one was an apprentice ritual at one time of day.
      Well i never was an apprentice & actually was appallingly bad at metal work in my school years.
      Was thinking of ground flat stock for material~hopefully build to last.
      Or is this going to be too hard?
      I can't see making the blade presenting too many problems, drill & file slot or drill & mill slot.
      The body has me pondering how to execute the slot well.
      Would be a little narrow for hacksaw & needle file i think.
      I can use slitting saw, but how to get end of slot finished to match angle on end of blade.
      Maybe you were an apprentice & made one?~ presumably by predominantly using hand tools.
      Any suggestions gratefully received~ how would you approach this?
      samuel heywood
        @samuelheywood23031
        #270477
        Journeyman
          @journeyman
          When I made one, rather a lot of years ago, the body was from three pieces two sides and a spacer from the same material as the blade all riveted together then filed. Couldn't see the join!
          Edited By Journeyman on 07/12/2016 16:51:39
          #270478
          Martin Connelly
            @martinconnelly55370
            Make the body by sandwiching some of the blade material between two thicker pieces and rivet together.
            Martin
            Beaten by 20 seconds!
            Edited By Martin Connelly on 07/12/2016 16:51:29
            #270484
            samuel heywood
              @samuelheywood23031
              3 piece sounds a much simpler method of acheiving desired goal.
              though I do like the elegance of a single piece of metal…..
              Plus i still have bad memories of riveting in metalwork….
              It must have been the most riveted adjustable spanner in the history of our school.
              The Metalwork teacher ( Mr Hall, but not the famous one) finally lost patience & tore me off a strip,he thought i was deliberately doing it wrong.
              In my defence i'm a southpaw.
              Maybe 30yrs on it's finally time to face my nemesis?blush
              #270490
              richardandtracy
                @richardandtracy
                Just remember, pop rivets are not a cop-out, they are a sensible solution.
                Richard
                #270493
                  I still have the tri-square I made at school you would think the stock was a single piece of metal not 3 bits of 1.5×20 bar and some rivits. I did make a sliding bevel too but don't know what happened to that.
                  #270508
                  samuel heywood
                    @samuelheywood23031
                    Ok, thanks for the replies.
                    I'll give the riveting a go.
                    #270528
                    Dod
                      @dod
                      If you are a southpaw then you need left handed hacksaws, files and a lefthanded 'ammer. wink
                      #270576
                      Hopper
                        @hopper
                        If you have a mill you could use a slitting saw. You would have to hold the body in the vice at the correct angle to get the angled end on the slot. But the three-piece construction will more likely give you a better surface finish inside the slot, which will give a smoother movement to the blade.
                        #270827
                        Ian S C
                          @iansc
                          One of my old books "Metal Work for Technical &High School Students with useful tables and data" By A. L. Hughes. 1945/47/51. mine is an Australian edition. It has a drawing for a sliding bevel, and it uses a bit of 3/4" x 1/16" spring steel for the blade, and the body is made from 3/4" x 1/8" mild steel. The rivets are made from lengths of 18" MS rod, the locking screw is a counter sunk !/4" Whitworth screw.
                          Ian S C
                          #270865
                          Enough!
                            @enough
                            Sliding Bevel Plan here
                            #270868
                              Posted by Bandersnatch on 09/12/2016 17:30:25:
                              Nice Plan yes
                              I hadn't seen that site before.
                              Unless riveting is a 'target' skill, however; I would be tempted to modify the body slightly, and use countersunk screws .
                              Enough!
                                @enough
                                Posted by Michael Gilligan on 09/12/2016 17:40:47:
                                Funny thing though. Riveting is certainly not my forté and I've shied away from it for years, finding alternative methods. I recently built the Acute Grinding System and it calls for one (turned) part to be riveted to a plate. So I decided to try again for a change and it worked out very well. Took just a couple of minutes and cleaned up invisibly. I was really pleased.
                                It might have helped that I used 12L14 for the turned part (leaded steel …. what you guys call EN-something).
                                Edited By Bandersnatch on 09/12/2016 18:32:38
                                #270887
                                norman valentine
                                  @normanvalentine78682
                                  As a left handed ex teacher of Design and Technology I used to get very cross with students who used their left-handedness as an excuse for incompetence. All it needs is practice and then more practice.
                                  #270914
                                  Dod
                                    @dod
                                    Ah but competent left handed folks still look strange doing things in a left handed way.
                                    I have practiced left handedness till I'm a fairly proficient ambdextrous handed person.
                                    #270944
                                    Nicholas Farr
                                      @nicholasfarr14254
                                      Hi, the plan in Bandersnatch's link is very much like the one I made in metalwork at school. Couple of slight differences are the blade was rounded at the end, same as the body, instead of being square, and the distance piece we had to hacksaw from the 45 degree end of the blade. So when the blade was folded inline with the body when not in use, the two 45's were in the same plain, so there was no significant gap between the blade and the distance piece.
                                      Oh! and we had to hacksaw the slot in the blade after drilling holes at each end. Don't know if I've still got the one I made, as I haven't seen it for a while.
                                      Regards Nick.
