Machining ali
Machining ali
Home › Forums › General Questions › Machining ali
  • #336735
    richard 2
      @richard2
      I have a Warco VMC mill with plenty of endmills.
      I need to reduce a 1.1/2" length of 1/4" x 1/2" thick ali down to 3/4".
      How big a cut can I take and about what speed?
      Many thanks for info.
      richard 2.
      #25755
      richard 2
        @richard2
        #336740
          Saw most of it off and then one pass to clean up the edge, its only 1/4×1/2 so can be sawn in a few secs
          If you prefer making swarf them hold it at the side of the vice so it is 1/4" high, 1/2" front to back. Use the side of a reasonable dia cutter and take 1/8" off at a time. speed will depend on cutter dia and type but fast as the machine will allow.
          Edited By JasonB on 14/01/2018 19:26:41
          #336966
          richard 2
            @richard2
            Thanks JasonB.
            That is just what I did only the few seconds turned into a few minutes – probably due to age!
            Anyway the job is done and it is now in the mill to have the slot milled.
            All the best
            richard2.
