Machine cleaning
Machine cleaning
Home Forums General Questions Machine cleaning
  • #366334
    Mark Gould 1
      @markgould1
      Gents,
      Has anyone got a tip for cleaning an Emco FB-2? I have noticed that machining most notably aluminium seems to leave a dirty mess and I was wondering does anyone have a good cleaning solution to cleaning the green painted areas of the mill itself but also the base.
      Thanks in advance,
      Mark
      P.S.I have tried with WD-40 which sort of works but requires a lot of elbow grease and the results are so-so.
      Mark Gould 1
        @markgould1
        #366339
        I.M. OUTAHERE
          @i-m-outahere
          For my mill and lathe i use some cheap spray on engine degreaser applied to a rag or paper towel . This stuff always pops up on special at a few of my local auto stores and i buy it by the box full spray cans of the stuff .
          #366340
          Martin Cargill
            @martincargill50290
            We have found that" Cillit Bang" works well for machine cleaning.
            #366343
            John Rudd
              @johnrudd16576
              I prefer to use an oil based fluid for my machines….be it WD40/paraffin or whatever….Wiping down after cleaning is bound to leave a least a thin film that ought to afford some protection against the dreaded brown stuff..
              Edited By John Rudd on 08/08/2018 18:44:10
              #366369
              larry phelan 1
                @larryphelan1
                I found white spirits to be as good as anything for cleaning. Get rid of the muck,then a wipe over with an oily rag.
                No muck,no rust !
                Friend of mine uses diesel,say,s it,s better than any cleaning product.
                #366392
                Ady1
                  @ady1
                  Machine what?
                  #366407
                  larry phelan 1
                    @larryphelan1
                    Another guy clams that if you have time to clean your machines,or your workshop,then you are not busy !
                    Not altogether sure I agree with that !
                    #366418
                    Nigel McBurney 1
                      @nigelmcburney1
                      Carburretor cleaner supplied in spray cans (halfords)will remove those brown stains left by soluble oil and old lubricating oil from the paintwork,Though I would not clean machined surfaces with any solvent as it removes lubricating oil,When I started in the 1950s every machine in our small works was thoroughly cleaned usually on Fridays,all swarf had to be removed ,slideways thoroughly cleaned and lubricated with oil can and rag,and the whole machine wiped down with oily rags.No slideway covers in those days,You would be in real trouble if you used compressed air a real no no.
                      #366980
                      Mark Gould 1
                        @markgould1
                        Gents, thanks for taking the time to answer. I will look into it all. My main worry is the painted parts. I know the machines are painted with machine grade paint but I dont want to ruin it,
                        Thanks again,
                        Mark
                        #366998
                        Jon
                          @jon
                          Carb and brake cleaners do very little and expensive conidering the amount needed.
                          We used parafin applied with a brush to clean off decades of grimed on grinding dust to congealed hardened oils.
                          The oly other thing found is the cheap £1 spray on Elbow Grease found in pound shops and the like, works superb on alloy wheels.
                          Discolouring of aluminums is oxide and will need stripping to some extent
                          #367016
                          John Haine
                            @johnhaine32865
                            Try Muk-Off? Good for bikes and alloy wheels. Halfords.
