Hi
I am yet another who has been lucky enough to inherit an ML7. My father bought it new in the mid-50's for less than £100 including a load of bits and pieces.
I have read as many of the previous threads that mention lubrication for the ML7 but I can't find the definitive on the following issue.
The lathe appears in excellent order and judging by the work he was turning out even in his late 80's/early 90's it is still very accurate. So I guess he had the lubrication right. As much as I would like I can't refer the question to him any more!
I am confused by the references to lubrication. I have the original Myford publication 701 and the more recently available re-prints of the "720". I have also read Ian Bradley's "Myford Series Manual".
I accept the change from EssoFebis K68 to a "good quality SAE 30 oil" and Esso Nuto 32 for the rest…
But the books/manuals put "stars" on "5"(Backgears and changegear over teeth),"7"(tumbler gears), "15"(Leadscrew), "16"(Rack), "17"(Cross slide and top slide feed screws.). The stars are referred to as needing Rotol MTS 1000 (a grease). But in the same page these same refernces have you apply SAE30.
Help….
Geoffrey HYDE FYNN
PS I am itching to check the installation but want the right lube first. Do we have an "approved dealer" of oils and suds?
