LED lamp failure
LED lamp failure
Home Forums General Questions LED lamp failure
Viewing 12 posts - 26 through 37 (of 37 total)
  • #332099
      Posted by Howi on 14/12/2017 09:12:05:
      I notice someone has mentioned the 'Blue light ' effect on humans, none of it has been scientifically proved. Just seems to be an excuse not to move to the new technology.
      Here is a very concise description of the two conventional methods of producing white light from LEDs.
      http://www.photonstartechnology.com/learn/how_leds_produce_white_light
      The problem with the 'Blue' is that it needs to be of sufficiently short wavelength to excite the Yellow phosphor.
      … and that lets its emission curve stray into the near-UV band [*], which has the potential to damage the eye.
      There is plenty more explanation available, from respectable sources, without having to rely upon internet wackos.
      This problem has reduced enormously in recent years, as the technology matured, and especially with the introduction of COB LEDs with their phosphor overcoat.
      Edit: [*] See the Spectrum plot on page 9 of this spec. [page 10 of the PDF]
      http://www.nichia.co.jp/specification/products/led_spec/NSDW510GS-K1-E(2619).pdf
      Edited By Michael Gilligan on 14/12/2017 22:34:22
      Howi
        @howi
        Posted by XD 351 on 14/12/2017 21:46:58:
        I think there is an awful lot of rot talked about led bulbs, a bit like the myth that ALL Chinese lathes are rubbish.
        In Philips bulbs the electronics are fully potted so unlikely to be affected by moisture. Lets be sensible here, moisture near any type of bulb should be avoided, 240 volts and water don't mix.
        Phillips led lights may be potted but the cheaper ones may not be . Mains voltage in the bathroom / shower area is unavoidable unless you use a candle or torch !
        My point was that all led bulbs from China are not equal , if the environment is harsh, get a better quality bulb to be on the safe side.
        Mains Led's in bathroom lighting can be replaced with 12 volt Led's, no need for candles or torches, let's be sensible here.
        #332121
          Your bathroom lighting should be waterproof and in the correct 'zone'.
          That's how we survived in the days between gas and LEDs
          Bill Dawes
            @billdawes
            XD351.
            The shower lamp I referred to is still original halogen, hence my reluctance to tempt fate by changing it to LED.
            My theory about its longevity is that the water vapour helps to keep it cooler than it would normally be.
            Still , when I have finished all my replacements I will swop it for an LED, as I said I have a box full of Halogen GU10's if the LED is no good.
            Bill D.
            #332296
            Anthony Knights
              @anthonyknights16741
              My bathroom light fitting is of the correct type for use in this location, with a rubber seal where the globe screws to the flush fitting ceiling mount. It has worked well over the years with both incandescent and minature fluorescent lamps.
              I have cut one of the failed LED lamps open and found what appears to be a minature switched mode PCB which plugs into the LED array. I haven't tested it yet, but I suspect that it is this part of the device which fails.
              #332298
              Gary Wooding
                @garywooding25363
                You might find THIS investigation into the failure of a LED bulb interesting.
                #332300
                Tim Stevens
                  @timstevens64731
                  Bill reminds us:
                  Which reminds me that condensation can be worse – much worse – with LEDs. This is because they only get slightly warm in use. So, the electronics, and the bulb-holder, etc, don't get hot enough to evaporate the dew in a steamy bathroom.
                  The same effect can cause problems with LEDs on vehicles, especially the outer lamps (as distinct from dashboard and other interior lamps). This is why encapsulation is an advantage, and why the super-cheap (non-coated) stuff can suffer.
                  Cheers, Tim
                  #332316
                  duncan webster 1
                    @duncanwebster1
                    Posted by Gary Wooding on 16/12/2017 11:07:58:
                    Now if that had been me I'd hve been out with the soldering iron and made 2 good ones out of 3 bad ones!
                    #332319
                    modeng2000
                      @modeng2000
                      Me too!
                      #332324
                      Sandgrounder
                        @sandgrounder
                        Posted by Bill Dawes on 15/12/2017 15:28:28:
                        Bill D.
                        But the halogen bulb is supposed to be run much hotter than ordinary incandescent bulbs, this is so the evaporated tungsten is re-deposited on to the filament increasing bulb life and keeping the bulb free of any blackening.
                        Hacksaw
                          @hacksaw
                          I may have asked a similar question before… These newer type Gu10 type , warm white , I'm very happy with.. Not one has popped ! Can you get the same but 12v D.C. for a caravan ?
                          #332373
                            Posted by Hacksaw on 16/12/2017 23:16:29:
                            As you presumably realise: GU10 lamps are, by definition, Mains Voltage
                            Warm White MR16 lamps would be ideal for caravan spotlighting, and are readily available.
