Posted by Andrew Johnston on 06/05/2019 22:20:25:
Posted by SillyOldDuffer on 06/05/2019 13:45:45:
I waffled about this in another recent thread. Briefly, the maximum currents quoted in the specs are peak, and they mainly occur during start-up.
I am not an expert! If a professional disagrees with any of the above listen to him.
I couldn't possibly comment on the last statement.
The first statement is correct but for the wrong reason.
Andrew.
Thanks for that Andrew. I find it hard to get my head round what the effects of starting and loading a 3-phase motor powered by a VFD might be on current flowing on the input supply. On average – I think! – a motor working at a steady rate is a good fit to this sort of analysis:
- The motor draws the same average current on each artificial phase.
- The current required by each phase is provided by the VFD. It does this by switching DC power stored in a capacitor such that each of three coils on the motor gets an approximate sine wave 120° out-of-phase with the others. But the DC supply simply 'sees' the total average load created by the sum of 3 averages.
- The DC power supply is sized to deliver the total average current. The capacitors need only be big enough to store enough charge to fill the gaps left between rectified half-cycles, ie the time the single-phase mains isn't providing current. Again simple enough to derive the average current.
- On the mains side, the supply 'sees' an average current that can be used to size the fuses.
If, god forbid, I was ordered to design such a set-up, I'd size everything relative to the power of the motor, working in watts rather than amps, and allowing for conversion inefficiencies. Thus a 1kW motor would get, guesstimated, three 400W switches and a 1.4kW DC power supply. The currents involved can then be calculated from whatever voltages are involved. For example, a 1.4kW supply on a 240V main would draw about 6A. I'd fit a 10A equipment fuse, and wire the whole to a 13A plug.
Trouble with my semi-educated approach is everything revolves around assumptions about averages. I don't believe this to be completely unreasonable, but the design is liable to come unstuck because it doesn't consider current spikes. These require deeper consideration of when current flows and why. Time matters in addition to volts and amps and this stretches my imagination and maths to breaking point. Examples of non-average current bursts include:
- Motor and other start-up surges
- Capacitor charging and discharging
- Harmonics and switching transients caused by the switches
- Harmonics and switching transients caused by the power supply diodes
I have severe difficulty imagining the effect of these non-sinusoidal demands on current flowing in a sinusoidal single-phase supply. In the same way I sort of understand the effect on power factor of an inductive load like a motor but I've no idea what putting a DC power supply between motor and mains does.
Now I'm thinking of experimenting with an oscilloscope in hope of capturing the current waveform when my VFD powered lathe is first switched on. If I put small resistor (20mm of Nichrome wire) in the Live, I can measure the voltage on both sides with a 2-channel oscilloscope. Never used it in anger, but my scope has a 'Math' function that displays the voltage difference between 2 channels, which I think reveals current. If so, the oscilloscope might catch what happens to mains current over several 50Hz cycles.
Might not be practical. The filtering on my lathe is basic and transients may mask the effect. This is assuming I don't make any accidental smoke wiring it up…
