J.T.Slocombe micrometer very old
Home Forums Workshop Tools and Tooling J.T.Slocombe micrometer very old
Viewing 25 posts - 1 through 25 (of 25 total)
  • #475202
    Former Member
      @formermember32069
      Former Member
        @formermember32069
        This micrometer is probably 100 years old.
        #475221
        Pete.
          @pete-2
          Cracking little mic, testament to its quality that it's still usable after all that time, I too have a weak spot for good quality measuring equipment, one of my best buys was a high resolution dial caliper 0.01mm, made in Japan by the NSK bearing company, I bought it new on ebay as old stock for £24, I wish I'd bought 2 of them now, similar quality calipers seem to retail at £100~£120
          #475228
          Hopper
            @hopper
            Slocombe of centre drill fame?
            #475232
            Sam Stones
              @samstones42903
              Perhaps not of the same vintage as your Slocombe Barrie, but close.
              It was going for 10/- (ten shillings) second hand in about 1950 shortly after I started my apprenticeship. For years, both during my time in the toolroom and later, I used it mainly for small work on the lathe. Never as a ‘G’ clamp, and seldom swung around like a clog iron.
              As a college metrology exercise, various tests showed where it had worn. Almost at a forensic level, there were clear signs on the anvil and a section of the thread of it having been used for round stuff in the range of 0.3" – 0.5" diameter.
              An optical flat, applied to the anvil, revealed a ‘valley’ and ‘hills’ at roughly 45°, evidence of (my) holding it in my right hand from under the workpiece. Regrettably, my notes have gone the way of many.
              The micrometer is still in my toolbox.
              Sam
              #475247
              Former Member
                @formermember32069
                #475263
                Bob Stevenson
                  @bobstevenson13909
                  Good story that made me smile!……I also have a collection of ancient 'mikes' including Starret, M&W etc.
                  New members to Epping Forest Horology Club who turn up with verniers and mikes are told by one of the tutors that they will mostly be using 'intuition and feel' and that their micrometer will be handy for clamping small parts but their v ernier should be left at home in future for removing the nuts on radiators etc.
                  #475270
                  Watford
                    @watford
                    Posted by Sam Stones on 27/05/2020 01:50:29:
                    Sam
                    Sam
                    I keep mine in my desk draw!! Does yours have 1/64"s on the reverse of the frame?
                    #475300
                    Greensands
                      @greensands
                      M&W 1/2 micI do find this one very useful as it is quite lightweight and convenient to take around in the pocket. Also very good for getting into tight corners. Picked up at an ME exhibition a few years ago, I think for 50p. It had apparently 'seized up'M&W 1/2 mic but a little TLC restored it to perfect working order. When will we next have the chance to scrabble around exhibitor's stalls
                      #475302
                      Former Member
                        @formermember32069
                        #475304
                        roy entwistle
                          @royentwistle24699
                          Incidentally does anyone know the correct lubrication for a 70 year old 961 Moore & Wright mike ?
                          #475310
                          Former Member
                            @formermember32069
                            #475312
                            Former Member
                              @formermember32069
                              #475323
                              roy entwistle
                                @royentwistle24699
                                Thank you Barrie
                                It was a Christmas present in 1949 along with a 4" square, 4" inside and outside calipers, a 6" rule and scriber all of which I was expected to have as a apprentice. I've still got all of them and still use them. I started work new years day 1950
                                Roy
                                #475326
                                Ron Laden
                                  @ronladen17547
                                  There is something very satisfying about having old tools that still work as good as when they where new.
                                  I recently was looking for an imperial 1 inch mic and was about to buy new when I came across a M&W 961B on Ebay for £8. Needed a clean but thats all, works perfectly, feels silky smooth and accurate when checked against slips, even came with the original case. I dont know its age but it must be getting on some.
                                  #475327
                                  Ron Laden
                                    @ronladen17547
                                    #475330
                                    Former Member
                                      @formermember32069
                                      #475422
                                      Pete.
                                        @pete-2
                                        Posted by Bob Stevenson on 27/05/2020 09:33:21:
                                        I like that, made me smile.
                                        #475423
                                        Pete.
                                          @pete-2
                                          This is the high resolution dial caliper I bought, really nicely made tool
                                          If you're after a 0.01mm reading dial caliper, Tesa make one **LINK**
                                          Edited By Pete. on 27/05/2020 19:56:23
                                          #475426
                                          Chris Gunn
                                            @chrisgunn36534
                                            Here is my vintage Mike, it is an Elliott, and is dual reading, the thimble can slide and be set to "English" or "French" divisions.
                                            dsc03646.jpgIt also has a ratchet for the right feel, way ahead of its time. I believe it could be pre 1850.
                                            Chris Gunn
                                            #475477
                                            Sam Stones
                                              @samstones42903
                                              Yes Mike, 1/64"s on the back.
                                              If you wonder about my name, 'D' is my first initial.
                                              As I said earlier it was second hand. It had been engraved with someone else's name before I stuck it onto the engraver.
                                              I took the trouble to move in close and perhaps for the first time noticed it was a No.230.
                                              Now for a short story …
                                              In the toolroom, we were discussing a very cheap brand of micrometer. They were die-cast in aluminium with a correspondingly low cost thread assembly. It may even feature here …
                                              [Search for die cast, there are two on Page 71]
                                              During the conversation, a story emerged about the ‘initiation ceremony’ of any freshly appointed toolmaker once they had settled in. For the initiation to work, it was also important that the new arrival was taking sufficient interest in their surroundings.
                                              The story continued, going something like this …
                                              Ensuring the new arrival could see him, Joe, one of the old timers shouts from far across the shop “Hey Fred, lend us thi nawt ta one!”.
                                              “Owd on a minit!” Fred would reply.
                                              He then proceeded to grab his extremely cheap micrometer from amongst his spanners, and pretend to measure something with a tight fist around the barrel. Then with a deft flick of his wrist, he would launch the mike along the concrete floor in Joe’s direction. Trapping it under one foot like a skilful soccer player, Joe would put on a good show of cranking the mike tightly onto a lump of iron, before whizzing the mike back along the floor in Fred’s direction.
                                              “Okay, thanks!” calls Joe, as the mike slid back to its rightful owner.
                                              With equal skill, Fred would grab the instrument, blow on it, and drop it back amongst his spanners.
                                              “Ta!”
                                              You can imagine the look of puzzlement and consternation on the face of the new arrival.
                                              Sam
                                              #475502
                                              Former Member
                                                @formermember32069
                                                #475503
                                                Former Member
                                                  @formermember32069
                                                  #475585
                                                  John MC
                                                    @johnmc39344
                                                    I've had this scruffy looking micrometer for many years. It was going in the bin because no one wanted it, no ratchet, stained and possibly a mixture of parts, the sleeve is plated, the rest isn't. I'm assuming that "1938" refers to its age?
                                                    I'm pleased I rescued it, its accurate and just feels nice to use.
                                                    Former Member
                                                      @formermember32069
