Is a tool & cutter grinder worth having?
Home Forums General Questions Is a tool & cutter grinder worth having?
Viewing 12 posts - 51 through 62 (of 62 total)
  • #773301
    Graham Meek
      @grahammeek88282
      I also forgot to mention that I have added an ER25 collet holder to the workhead. Instead of the GHT derived holder shown. The workhead can also be moved on guided rails to make positioning the workpiece easier. This ensures no loss of position and the work always remains on the original centreline.
      Gray,
      Howard Lewis
        @howardlewis46836
        Without realising it, I followed Giles Parkes and made up a ER20 collet holder for my Worden. Far better than having to store dozens of individual collets for all the various drill sizes.
        Another simple jig is used to set the cutting edge vertical in the holder. And being square makes 180 degree rotation for the second lip so easy.
        #773346
        Fulmen
          @fulmen
          I haven’t really thought much about work holding yet. I’ve just started on the toolholder, but I now realize that while it has a 25mm bore it can’t hold a 25mm mill easily. I have several 25mm HSS mills that will need maintenance so I need to figure something out. Redesigning it to a 30mm bore is possible, but this would mean scrapping several hours of work. And while it’s not a major redesign I don’t want to complicate this build more than I have to now.
          #773609
          Howard Lewis
            @howardlewis46836
            How about making a V block and clamping the cutters into that?
            That is how drills are held in some of the drill grinding attachments for the Worden.
            You will probably have to make up a fixture so that the cutter is correctly aligned ready for grinding.
            #773651
            old mart
              @oldmart
              At the museum, we have a box with a couple of hundred threaded shank HSS milling cutters. Not much use to us as they all need sharpening. I long ago removed the usable ones and put them in tubes. We have about 60 sharp or newones, but as we cannot sharpen them, they are kept for use with softer materials and solid carbide is used for harder work. I had a taper ground on the end of one of the blunt ones to produce new  keys for the Smart & Brown model A compound. It was done by the friend of one of the volunteers to match the 55degree included angle of the dovetail track in the cross slide.
              If you have a fully kitted cutter grinder specials can be made for specific jobs and it could also be used for lathe tools and drills as well.
              It all boils down to whether the budget and space plus the need for having one all coincide.
              #773721
              David George 1
                @davidgeorge1
                I have started to modify my Taylor Hobson cutter grinder, which was made to grind cutters for a pantograph engraving machine. I have made a cross slide from a cross slide from a Myford lathe and a chunk of cast iron and other bits and pieces firstly to give me a base to add cutter holders.
                20241219_154519
                I have also started on design for holding the ER collet set and to give it angle and depth movement.
                Tool grinder mod top slide assembly
                This will have in and out slide, rotation on base and rotate up and down on other axis to allow angled cutters and shallow angles on bottom of end mills etc.
                David
                #773740
                Clive Foster
                  @clivefoster55965
                  David
                  Thats an interesting project.
                  However I do wonder why you went for an all new build rather than adapting one of the “U2” milling cutter holders made for the import Deckel cutter grinder clones that can be found for £100 – £150. Which doesn’t seem to be completely beyond budget. Your Taylor Hobson grinder being, I think, sufficiently similar to the Deckel clones that adaptation is quite feasible. Although the as supplied fit and finish of these imports is generally said to be agricultural it does give you all the bits and nice dials. Best thought of as a part machined kit I guess.
                  The prime limitation seems to be the limited collet size range and cost of around £20 per collet from the usual suppliers.
                  I’m interested because I’m wondering whether the nice scales et al would make one worth modifying for my Clarkson as an improvement on the rather basic standard work head. But I wouldn’t use U2 collets.
                  #799335
                  Tony Pratt 1
                    @tonypratt1
                    I’m in need of 3″ dish shaped grinding wheels for my Stent cutter grinder but I think such a thing is no longer manufactured.
                    Does anyone know of a source that I might try?
                    Thanks
                    Tony
                    #799341
                    Clive Brown 1
                      @clivebrown1
                      #799348
                      Howard Lewis
                        @howardlewis46836
                        Made a Worden, many years ago. Enables drills to be kept sharp and accurate (Made up a holder for ER20 collets) using four facet method. having a square holder, enables the drill to be turned over after every cut, so that the lips are the same length, and it will cut to size.
                        Have also ground a few End Mills, and with a diamond wheel, an inserted tooth carbide face mill.
                        Superb for tool bits for use in the lathe, or a flycutter.
                        Obviously,, not used every day; but invaluable when needed.
                        Am in process of making one for the Water Works Museum, so that they can sharpen their drills and tooling better.  (Had forgotten how much work involved, but satisfying to see it taking shape).
                        #799379
                        Tony Pratt 1
                          @tonypratt1
                          On Clive Brown 1 Said:
                          Try Midland Abrasives;https://www.midlandabrasives.com/categories/products/dish-grinding-wheels-html/
                          Thanks Clive , just what I want!
                          Tony
                          #799431
                          bernard towers
                            @bernardtowers37738
                            As Howad says not used everyday but wouldnt be without mine (Stent) and have made many little njigsn and holders over the years which you now just pick up and use without really thinking about it. I even have a small motorised headstock for mine (grinding carb needles)
