Thanks for the replies and much needed information .
I had a dig around on the net to see what is available in the way of reasonably priced inverter units and found one made by hounyang (think thats right ) anyhow after a good read of the specifications it seems it has connectors for external emergency stop and braking resistor along with a lot of other featurs i probably will never use .
It has ramp up/down or coast stop features etc and amazingly cost less than the DC controller for the C2 lathe – can't work that one out !
All the components on the DC controller wouldn't cost $20-$30 !
While i'm on here i may as well ask if anyone has a recomendation for motor power rating to use on the C2 ? Original unit was around 400w DC so would a .55KW 3PH unit suffice ?
I have plenty of room behind the machine so physical size is not a problem withing reason anyhow .
I know on the larger lathe it has a .55KW motor single phase and it has been fine as the machine has a 6 speed v belt drive
I will have to make some pulleys for the C2 so i may as well make some 3 groove vee pulleys to give 6 speeds in total using the high and low gearing in the head .
That way i can use the VFD to fine tune my speed settings as needed without slowing the motor speed down too much .
Any thoughts welcome .
Ian
Edited By SLOTDRILLER on 20/03/2013 19:28:25
