Insert tool cutting angles
Home › Forums › Workshop Tools and Tooling › Insert tool cutting angles
  • #519205
    Greensands
      @greensands
      I am considering buying a VCGT carbide insert straight turning and facing tool in order to get into some tight corners. Can anyone help me with the size of the pointed angle of this tool?
      #20094
      Greensands
        @greensands
        VCGT
        #519208
        Dennis R
          @dennisr
          Just Googled VCGT carbide insert angles and it came up with 35*
          Dennis
          #519218
          Emgee
            @emgee
            You won't get into tight corners using a Straight (Neutral) holder, you will need either or perhaps both RH and LH to reach all corners.
            Emgee
            #519234
              Although a handed tool is best you may be able to get into corners with a neutral if you angle the tool holder depending on the actual part..
              Your tight corner will have a small internal fillet determined by the inserts corner radius, pick one with a 0.2mm radius for minimal fillet.
              Edited By JasonB on 12/01/2021 06:59:39
