Hydraulic Motor
Hydraulic Motor
Home Forums General Questions Hydraulic Motor
  • This topic has 13 replies, 11 voices, and was last updated 26 May 2020 at 12:14 by Alistair Robertson 1.
  • #474935
    Chris123
      @chris123
      Evening, we have a hydraulic motor (the motor turns on hydraulic flow, it isn´t an electric pump).
      Where is the best place to ask advice on this, I´ve posted on a different forum but haven´t had any replies.
      Basically, we have a hydraulic motor that has thrown off the rings that connect the pistons together, it has happened on both sides. Can these parts be replaced? We've been informed that we need a new motor, at the cost of several thousand pounds. But I'm struggling to believe that we can't make new rings for it.
      Chris123
        @chris123
        #474944
        not done it yet
          @notdoneityet
          I would be using google to search out a company willing and able to effect repairs or advise. Your motor may well be thousands of pounds to replace – it rather depends on unknown factors. Ask the experts – is my advice – and get more than one quotation for a repair or relacement.
          #474953
            You may get more helpful responses, Chris, if you could give us a few more details of the motor.
            The size, and a description of the basic design, would be handy … and photos of the failure would help enormously.
            HOWARDT
              @howardt
              AC Hydraulics You may get an answer from this company. Used it for years during my working life, though it has changed during recent years. Pump, as well as most hydraulic components can be rebuilt but will depend on damage susbsequently caused by the failed component.
              #474996
              Chris Evans 6
                @chrisevans6
                In my working life I used a few hydraulic motors for our applications. All where made by "Danfoss". Worth a Google to see if they are still around ?
                #475006
                Bo’sun
                  @bosun58570
                  Hi All,
                  Yes, concur Danfoss. Although they were based in Denmark, they had a UK office in West London. They were an excellent company to deal with. Not sure, but they may be tied-up with Sauermann (Sauer-Danfoss). There are also a number of hydraulic component "re-manufacturers" around, and that would be one of my first ports of call.
                  And, as has been said, some more detailed info' would also help.
                  #475008
                  David Jupp
                    @davidjupp51506
                    It should be relatively easy to get assistance for 'common & current' hydraulic motors. For old or very specialised items it may be more hit and miss.
                    I'm aware of one particular range of hydraulic motors where the (very old) design rights have been sold on and a small specialist supplies parts to a limited size, but critical market.
                    #475009
                    Adrian R2
                      @adrianr2
                      Hydraulic motors are common on agricultural equipment, so if you happen to live in rural parts then an ag. engineering firm may be able to help.
                      #475012
                      Ady1
                        @ady1
                        They always cost an arm and a leg 'dem things
                        You may get lucky and find a good ex-employee/tradesman, like with roofing/plumbing etc who charges sensible prices
                        Maybe if you you look for "refurbished" motors
                        #475013
                          @alistairrobertson1
                          Hi, Chris.
                          There are multiple types and makes of hydraulic motor but they almost all do the same job. They take hydraullic flow and pressure and convert it in to rotary motion which does the work required. Get the make of the motor and any numbers and I am sure an equivelent can be found that will work. You mention pistons and huge cost, perhaps it is a Hagglands motor as these two things go together when mentioning them!
                          #475016
                          Ady1
                            @ady1
                            Hagglunds lol
                            We had their hydraulic cranes on one ship, omg
                            #475023
                            Mike Poole
                              @mikepoole82104
                              As with others I am not visualising this motor, a bit more info would help. Many of the components in an hydraulic motor have tight tolerance and finish and will require grinding equipment to replicate, material spec and heat treatment are other unknowns.
                              #475064
                                @alistairrobertson1
                                I've just had a thought. Many years ago we got a call to look at a piston type hydraulic motor, I think it was a Dunlop/Dowty type. It consisted of I think 7 radial pistons bearing on an eccentric central shaft/cam. The guide plates at each side had broken. We managed to get or make replacements and when we looked for a cause it was a sticky valve that was restricting the return flow and creating over pressure in the system. Whatever we did must have worked as we were never called in again and the company was only a few hundred yards down the road and we did lots of other work for them.
