Posted by Robert Atkinson 2 on 27/09/2018 17:50:01:
Posted by Bill Chugg on 27/09/2018 16:55:11:
My workshop was 5 metres from the house at my last property.
Electrician used 6mm SWA as supply as he said that was the minimum he could use to comply with the regulations.
Thats just wrong, 6mm SWA is rated for at least 50A. A workshop feed should not need more than 32A. 2.5mm would do for a short run and 4mm would be conservative. Too late now though.
Robert.
I'm sure there are many forum users who have machines or plant in home workshops that have a need for more than a 32A supply so I believe the advice to use 6mm SWA was sensible, even for such a short run, the cost difference was negligible.
There will also be many who experience the lights dipping or even going off when starting machines or plant, some of those will have undersize supply cables.
Perhaps the cable was routed through a boiler room with high ambient temperature and both walls where the cable passed totally enclosed the cable in insulation, there may also be any number of live circuits on part of the route.
Without knowing the exact details of the installation it is impossible to say the cable is not a good choice.
Emgee
