How would you fix this?
Home Forums The Tea Room How would you fix this?
Viewing 25 posts - 1 through 25 (of 34 total)
  • #366372
    Sherlock
      @sherlock
      Since there are some great minds in here I thought I would ask..
      So the problem is, the plastic threads on the dishwasher salt compartment have stripped and consequently does not seal anymore, so it's making everything rusty. I think it's possibly the tank rather than the actual cap that is stripped which is a bit of a nightmare to replace the whole salt tank…
      so i need some kind of universal sealing cap of sorts that is water tight?
      Iv'e tried wrapping the existing threads in PTFE tape but doesn't hold up in the wash. I'm thinking of a large hose clip holding something on? a bit of a marigold glove?
      Any better Ideas?
      Sherlock
        @sherlock
        #366375
        FMES
          @fmes
          Use 'all in one' dishwasher tabs, you won't need the salt then.
          #366378
          Vic
            @vic
            Posted by FMES on 08/08/2018 21:21:20:
            Aha, that’s thinking outside the box! smiley
            #366379
            Speedy Builder5
              @speedybuilder5
              Which dishwasher and how old is it?
              #366380
              Sherlock
                @sherlock
                That is an incredible solution! teeth 2 I must admit, I never even thought of that, but, I just checked and the tablets we are using claim to be 'all in one' but the dishes are just not getting clean without the 'additional salt'.
                Maybe I can try another brand and hope their salt content in their all in ones have higher salt content, I don't know… I have heard that apart from softening the water (hard water area here) they also provide some abrasion in washing. Not sure how true that is but makes sense.
                Edited By Sherlock on 08/08/2018 22:14:47
                #366381
                Sherlock
                  @sherlock
                  Posted by Speedy Builder5 on 08/08/2018 21:47:51:
                  It's a 'Stoves' S450DW slimline one about 3 years old or so, I checked on the warranty situation but it's expired
                  Edited By Sherlock on 08/08/2018 22:13:04
                  Edited By Sherlock on 08/08/2018 22:13:39
                  #366383
                  HOWARDT
                    @howardt
                    Have you looked on the various spares companies sites, they seem to have salt containers on the one I looked at.
                    #366384
                    Sherlock
                      @sherlock
                      Posted by HOWARDT on 08/08/2018 22:31:20:
                      Yeah unfortunately not a lot available for that model. Stoves sells spares direct but nothing for that model.
                      To be honest I am trying to resist replacing the container itself as the unit is integrated and really not looking forward to un plumbing, laying the unit on its back and taking the bottom off. I hate plumbing related chores
                      #366389
                      Fowlers Fury
                        @fowlersfury
                        If the stripped threads are external on the tank can you not turn up a nylon or polyethylene 'bung'?
                        Conversely, if the threads are internal, then turn up a push-on cap?
                        #366391
                        Sherlock
                          @sherlock
                          Posted by Fowlers Fury on 08/08/2018 23:42:11:
                          Thanks, yes a bung might do it. maybe if I use a rubber one it will hold in with friction.
                          #366403
                          not done it yet
                            @notdoneityet
                            I suppose we have to assume your water supply has a fair degree of hardness? Without a profile, we are unable to gain any idea of the water supply chemistry in your area. There is possibly a case of just not needing a water softener at all.
                            #366404
                            pgk pgk
                              @pgkpgk17461
                              Posted by Sherlock on 09/08/2018 00:13:19:
                              Some model aircraft fuel tanks improve on simple insert friction by sandwiching the bung between two supports and compressing it after insertion to expand radially. Usually simply with a through pin somewhere on the radius to prevent twistng and a central bolt to pull up the inner support.
                              pgk
                              #366405
                              David Mitchell 5
                                @davidmitchell5
                                It might be worth checking this website for spares: **LINK**
                                Also, I recall that Stoves were re-brand Hygena. The joys of fittings a couple of kitchens over the years, and helpful chap at well know trader only kitchen suppler informed of this.
                                #366406
                                clogs
                                  @clogs
                                  we have the hwhole house water softened except for a seperate drinking water system and thats triple filtered….
                                  #366427
                                  Russell Eberhardt
                                    @russelleberhardt48058
                                    I've always been doubtful of those. The dishwasher manufacturer builds in a water softener for a good reason. If hard water dries on the dishes it will leave the hardness behind as cloudiness. The salt doesn't go into the washing water. It is used to regenerate the ion exchange resin in the softener. So how can an all in one work? It cannot remove the calcium ions from the water can it?
                                    Russell
                                    #366435
                                      Posted by Russell Eberhardt on 09/08/2018 11:29:48:
                                      By chelation as I understand it.
                                      N.
                                      #366436
                                      Sherlock
                                        @sherlock
                                        Posted by not done it yet on 09/08/2018 08:15:43:
                                        Yes, it’s a hard water area Calcium carbonate(CaCO3): reads at 286 ppm (per litre)
                                        Posted by pgk pgk on 09/08/2018 08:31:18:
                                        That sounds good. When I woke up this morning on a fresh head though, I realised the centre of the original cap actually depresses inward like a float so its not air tight all the time, presumably its way of dispensing the salt? So am wondering wether the whole sealing off completely by whatever means is actually going to work. Not entirely sure how these caps dispense or the purpose of the moving centre in the cap.
                                        Posted by David Mitchell 5 on 09/08/2018 08:58:12:
                                        I never knew that and is worth knowing, cheers I will check that out
                                        Posted by clogs on 09/08/2018 09:04:07:
                                        We have actually been considering that, how ware you finding it? did you get the water filter and softening kit from the same company?
                                        I think I am gonna try crawl in there today (oh the joy) and inspect the threads properly to be certain. If they are knackered I might just try some super glue mixed with baking soda on there then file it down to redress the thread.
                                        #366438
                                        FMES
                                          @fmes
                                          Russell
                                          Most American dish washers don't have softeners built in for exactly the reason you quote, the whole house has a softened water supply.
                                          All in one tablets do not have anything to do with regenerating the resin in the softener, but merely stop the calcium etc from adhering. They actually do the same job in reducing calcium deposit the same way Calcon does for washing machines.
                                          Funnily enough, they don't have softeners built in either.
                                          #366439
                                          not done it yet
                                            @notdoneityet
                                            If you go the whole house route for a water softener, consider plumbing in the loo (as well as the drinking water supply before the softener) straight from the mains. It will save you a lot of salt.
                                            #366447
                                            FMES
                                              @fmes
                                              Posted by not done it yet on 09/08/2018 12:25:02:
                                              Salt is a lot cheaper than loo cleaner, and have you looked inside your cisterns lately?
                                              Softened water will keep it spotless.
                                              #366448
                                              FMES
                                                @fmes
                                                By the way, whats wrong with drinking softened water?
                                                #366452
                                                  Posted by FMES on 09/08/2018 12:41:44:
                                                  Tastes nasty and has extra Sodium in it (The Calcium salts causing hardness are replaced by Sodium salts.) No problem for a fit young man, not so good if the doc has ordered you to reduce Sodium.
                                                  Soft water is good for cleaning and boilers, not cooking.
                                                  David Caunt
                                                    @davidcaunt67674
                                                    We have had a water softener since the early 80's. The word was then that it wasn't good for babies to have water softened in case it contained a trace of Sodium. As this didn't apply in our case our total water supply (other than a feed to our hose pipe). is softened.
                                                    We have never notice any nasty taste and my wife only drinks tea or water. We would recommend it to anybody.
                                                    #366464
                                                    FMES
                                                      @fmes
                                                      Posted by SillyOldDuffer on 09/08/2018 12:54:03:
                                                      For info, there is less sodium in a glass of softened water than there is in a glass of cows milk.
                                                      So is not in any way harmful to adults, although there is the said recommendation for not giving it to babies, although a decent RO Filter will take out any impurities that may have been left behind.
                                                      The water company will also make a recommendation to keep one tap 'untreated' as they cannot guarantee the quality of the product if additional conditioning / treatment is carried out after theirs.
                                                      And its 'softened' not soft.
