How would you design a extra mini lathe (Adept size)
Home Forums General Questions How would you design a extra mini lathe (Adept size)
Viewing 25 posts - 1 through 25 (of 86 total)
  • #204423
    Rainbows
      @rainbows
      I like the concept of the Adept size super small lathes but it must be reluctantly admitted (or shouted with a megaphone from the rooftops) it wasn't that well made. The Wizard I own is certainly better but still no Schaublin.
      Has anyone ever made a lathe of similar capacity out of stock metal? I have access to a lathe and mill (though the only tools I personally own are non functioning ).
      I have some vague sketches and anything that has bearings and proper more tapers would probably be an improvment over an adept but I wouldn't call myself an expert lathe buillder so I thought I would just throw a line out and see if anyone has made one before and could show how they went about it or give hints. I did read through the Gingery lathe book but thought some parts of it made things excessively bodged in the name of saving pennies.
      Rainbows
        @rainbows
        #204425
        V8Eng
          @v8eng
          Many years ago LC Mason built quite a neat one, I think it was from stock materials but I cannot remember much of the detailed stuff.
          He wrote a book called 'Building a Small Lathe' (not sure if it's still in print though).
          Edited By V8Eng on 15/09/2015 21:34:53
          #204432
          NJH
            @njh
            Yep – that's quite right – L C Mason wrote a book Building a Small Lathe. This was made from stock materials. I just had a search through my bookshelves and can't locate it. I recall that it was a small machine and LOTS of work to make and quite a lot of material to buy first. The book is still readily available – usual sources!
            I think that if I was in the situation with no lathe, and desperate to get one, I would opt for the largest of the mini lathes that I could run to ( Arc for example) have a selection.
            Norman
            #204438
            Rainbows
              @rainbows
              His was backgeared and screwcutting, for the cost of a set of gears on the internet you could buy many lathes.
              #204441
              bodge
                @bodge
                [Thought some parts of it made things excessively bodged in the name of saving pennies.] I think you mean botched ! Theres nothing wrong with any thing thats been bodged, the bodger in the lodge does some pretty good bodging !
                bodge.
                #204462
                Rainbows
                  @rainbows
                  Oh of course wink 2 But then there is having the user gauge their holes with a feeler gauge and an inside calliper because a vernier calliper would be too expensive
                  #204472
                    Posted by bodge on 16/09/2015 00:17:36:
                    bodge.
                    I'm glad I'm not the only person who distinguishes between 'bodge' (making do with available materials) and 'botch' (screw up).
                      Posted by Rainbows on 15/09/2015 23:54:14:
                      But if you are making a lathe then why would you not cut your own gears, could be done for the cost of the bar stock and a few bits of silver steel to make your own cutters
                      #204479
                      David Clark 13
                        @davidclark13
                        L C Masons book is still available from Ebay and I think TEE Publishing may stock it.
                        #204496
                        Cornish Jack
                          @cornishjack
                          Started to make one of these at Witney Tech College evening classes in the 80s. Still have the bits (I think!!) among the stored recovered rubbish from the flood. Last seen it was very rusty but (by my standards!!) not bad. I had got as far as the top slide and cross slide plates before having to give up the classes. I had also managed to cut the lead screw – highly chuffed at that!! Given that I was able to progress it that far, anybody with an ounce of REAL basic engineering skill could make a really nice little home build job of it.
                          rgds
                          Bill
                          #204498
                          Anonymous
                            Posted by Neil Wyatt on 16/09/2015 08:33:47
                            According to my dictionary they're the same thing – "to make a mess of"
                            #204506
                            Ajohnw
                              @ajohnw51620
                              Posted by Andrew Johnston on 16/09/2015 11:25:47:
                              LOL It's funny how often people comment on word use like this but don't check.
                              Ajohnw
                                @ajohnw51620
                                I seem to remember a very simple design appearing in one of the model engineering mags some time ago based on using a bar for the bed. Might have been MEW. Probably square bar rotated by 45 degrees.
                                There are some interesting ideas from older lathes. For instance one plain lathe uses a totally different saddle for screw cutting. That is then moved along the bed to where it's needed just like the usual slide arrangement.
                                Some old cheap lathes used nothing more than a pair of round bars for the upper slides rather than dovetails. Some also used Myford type bed rails on the upper slides.
                                My father reckoned the best way to get a super precision small lathe was to make one myself. I'd been thinking in terms of using flat ground stock sections. His attitude was why – ordinary steel sections only vary by thou's. Makes sense really as things are going to have to be fitted and dowelled / double roll pinned.
                                He mentioned that an interesting lathe with an unusual design of bed was produced by one manufacturer just after WWII. A slant bed. They can have larger swings and be very rigid compared with ordinary beds. The saddle hangs down from the back so the bearing surfaces can be very large. Trouble is that the cross slide needs to run horizontal. I'd guess he was thinking in terms of a very thick fairly wide steel section. I feel it would be too difficult to make but he might have been suggesting a rather unusual spindle to bed arrangement – bed flat and spindle moved back rather than on centre. Not sure. He'd usually only gave me clues especially as he got older.
                                One thing that is a fact is that plain bearings are best. It struck me that oilite's could be used to save keeping on having to make them. Maybe even running on needle roller bearing inners pressed onto the spindle. it wouldn't be too much of a problem to make an attachment that could be fitted to the bed to finally size both the bearings in the head stock and the tail stock by hand. It should be just a case of removing a few thou of material. From what I can gather this was done by people a long time ago to save the pain of having to accurately scrape them. The manufacturers have used similar ideas even jigs to position and size them often rotating so that both bearing can be at the same height and alignment.
                                Thrust – a race of some sort will be best for that but for insanely high speeds I suspect Pultra used hardened steel running against phos bronze as I feel that the thrust bearing they used on some would have a hard life at 10,000rpm.
                                crying I think about the slant bed and wonder how every now and again. I wonder if what he was thinking about would be better described as a slant head. In my minds eye it makes sense.
                                  Posted by John W1 on 16/09/2015 11:56:08:
                                  Indeed, if they did (or they knew any practising bodgers – green woodworkers, a very skilled craft) they would know the truth:
                                  http://www.potterwrightandwebb.co.uk/wood-2/a-bodger-is-not-a-botcher
                                  Ajohnw
                                    @ajohnw51620
                                    Collins gives the info a bit quicker than oxford Neil but both infer the same thing –
                                    After all Collins is concise.
                                    laughYou'll get me going on the phrase "this begs the question" if and when comments crops up.
                                    Gordon W
                                      @gordonw
                                      I was accused of being a bodger the other day, my reply was -" yes and it's still working." Rather proud of my bodging.
                                      #204569
                                      Vic
                                        @vic
                                        I'd look into the possibility of using ball screws and linear guides. We had a small CNC mill at work that featured both and that seemed to work well enough.
                                        #204572
                                        David Clark 13
                                          @davidclark13
                                          Hi John W1 I think that it was in Engineering In Miniature.
                                          #204579
                                            Posted by John W1 on 16/09/2015 16:06:08:
                                            Language evolves and changes; usage counts more than dictionaries, they can only play catch-up. The resurgence in green woodworking over the last thirty-forty years the distinction has become stronger.
                                            The opposite trend is how jury-rigged (an operation demanding great skill) and jerry-building (the opposite) have become conflated in the term 'jerry-rigged'.
                                            Vic
                                              @vic
                                              I'd probably use something like a C20 ER20 milling chuck and some chunky pieces of ground flat stock pinned and bolted together would make a good bed combined with linear guides. Thick walled box tube for the head and a variable speed drive would complete the basic structure. Biggest problem I see is aligning the spindle with the bed and fabricating/aligning a tail stock.
                                              #204598
                                              Nigel McBurney 1
                                                @nigelmcburney1
                                                Best bet would be to use an existing small lathe and spend some time improving it ,similar to Martin Cleeves mods to an EW Lathe described in ME many moons ago.
                                                #204613
                                                Steve Withnell
                                                  @stevewithnell34426
                                                  Posted by Neil Wyatt on 16/09/2015 14:46:15:
                                                  Maybe the clue can be found in the Bodger's Lodge…
                                                  Edited By Steve Withnell on 16/09/2015 20:39:14
                                                  #204629
                                                  Ajohnw
                                                    @ajohnw51620
                                                    Posted by Neil Wyatt on 16/09/2015 17:45:12:
                                                    The oxford dictionary doesn't take anything like that length of time to update Neil. The real source for Collin's too but more concise. Both probably give all meanings of both words which will have wider scope than the things under discussion anyway. This begs the question should dictionaries ever be updated. I'd beg to differ.
                                                    Ajohnw
                                                      @ajohnw51620
                                                      devil Some might need explanation of why begs the question is interesting. Thankfully the wiki has been updated
                                                      It did refer to some Gaelic person that probably couldn't speak English properly who a long time ago said that the phrase was circular
