How can I tell if it’s cast Iron
Home Forums Beginners questions How can I tell if it’s cast Iron
  • #9418
    Iain Downs
      @iaindowns78295
      Yes – I should have labelled it….
      Iain Downs
        @iaindowns78295
        Hi, all.
        Over the last couple of years I've bought a bunch of material for one project or another. Most are still on the drawing board and I've lost track of quite a few of them.
        One thing that's left me with is some metal whose purpose I no longer recall – if, indeed, I bought it for something in particular and not just because it might come in useful someday.
        There's a block I will use for some bearings if it's cast iron – and not if it isn't.
        How do I tell?
        I thought I could scrape a bit – steel seems sticker to me than cast iron, but this wasn't conclusive. I can probably try and machine some. My experience is that cast iron comes of as grit and steel as streams or chips.
        Is this reasonable accurate? Is there any easy way of doing this?
        Thanks
        Iain
        #381271
          Put it against your bench grinder, if grey CI then you will get dull red sparks
          #381273
          mechman48
            @mechman48
            File it; if CI it will produce grey dust.
            George.
            #381275
            not done it yet
              @notdoneityet
              Turning or milling will easily discern between the two – like the filing suggestion, by mechman48
              #381322
              Martin Connelly
                @martinconnelly55370
                I can usually tell when I am working with cast iron because it smells what I can only describe as earthy. Most other materials don't have such a distinctive smell.
                Martin C
                #381452
                Jon Lawes
                  @jonlawes51698
                  Posted by Martin Connelly on 19/11/2018 08:04:00:
                  Martin C
                  I'm glad I've heard someone else say it! I'd never have admitted it myself otherwise. It does have a distinctive smell.
                  #381458
                  Fowlers Fury
                    @fowlersfury
                    Easy – if you're married……
                    Machine, file, emery or whatever the metal then wash your (black) hands in the domestic sink.
                    Next morning if you are subject to dog's abuse for all the minute rust stains on the sink's surface, it was cast iron.
                    #381460
                    colin vercoe
                      @colinvercoe57719
                      Grinder dull red sparks -cast iron
                      bright yellow – steel
