How Accurate Are Low Cost Digital Calliper Micrometers?
Home Forums Beginners questions How Accurate Are Low Cost Digital Calliper Micrometers?
Viewing 20 posts - 51 through 70 (of 70 total)
  • #92500
    Tony Jeffree
      @tonyjeffree56510
      Posted by Terryd on 26/04/2012 07:25:08:
      Fortuntely the decimetre seems to have disappeared
      T
      Edited By Terryd on 26/04/2012 07:26:24
      Presumably it has been decimated…?
      Tony
      Tony Jeffree
        @tonyjeffree56510
        Posted by Andrew Johnston on 25/04/2012 21:05:00:
        Hmmmm, what a vulgar discussion, let us hope it stays rational and proper, and doesn't veer into the improper.
        …and those Metric bigots all seem to be just a bit too "holier than thou" don't they?
        I'll get my coat…
        Tony
        #92508
        Sub Mandrel
          @submandrel
          Posted by Tony Jeffree on 13/06/2012 18:16:31:
          T
          Reduced by 10% That would leave us with ninometers.
          What I can't understand is why we use hectares instead of ares.
          I'm off for a hectolitre of best scotch.
          Tony Jeffree
            @tonyjeffree56510
            Posted by Stub Mandrel on 13/06/2012 19:49:26:
            It all goes to show that units of measure are a pain in the ares. Mind you, after a hectoliter of best scotch, you would have a wee pain in the wallet, not to mention the head
            Tony
            #92526
            Anonymous
              Posted by Tony Jeffree on 13/06/2012 18:20:34:
              I'll get my coat…
              Tony
              Hmmmmm, I can't work out if I'm being agreed with, or insulted…………
              PS: I am assuming that people understood the mathematical connotations in my original post.
              #92531
              Howi
                @howi
                Posted by Peter G. Shaw on 15/05/2012 17:28:35:
                Morgan,
                Yes, the Strowger System was reputedly invented by Almon B. Strowger who was indeed American, but the system was much refined into the eventual workable system that we all love. Or hate!
                Having said that, the GPO as it was, initially used Strowger type selectors from a number, five I think, of different companies, which although they fitted a standard cradle and bank, were between themselves not really compatible, ie spares for Siemens, say, would not fit, say, ATE. Then, in the '30's I think it was, the GPO designed it's own Strowger selector which was called the 2000 type and all manufacturers built to this design, hence solving the spares compatibility problem.
                The 2000 type selector had a number of other advantages as well over the older selectors which became known generically as pre-2000. The 2000 type switch lasted until the demise of the Strowger system in the UK although there was an attempt in the '60's to introduce a cheaper alternative. This was, unsurprisingly, known as the 4000 type selector and was functionally identical to, and hence fully interchangeable with, the 2000 type and used the same cradle and bank. However, it did not last because, I believe, it was not as reliable as the 2000 type.
                Peter G. Shaw
                Edited By Peter G. Shaw on 15/05/2012 17:32:02
                Those were the days! I have worked on all thiose systems, before moving onto Crossbar, TXE2 and 4 and finally system x and y.
                While the older strowger type equipment kept a lot of TO's inemployment with an amazing array of adjustment tools. the modern electronic sytems we now have, only require the TO(i think there must only be one left now!!!) to have an Alsation dog rather than a toolkit.
                The dog being there to stop the TO from touching the equipment, as engineers messing with the kit caused more problems than leaving it alone…………………
                #92536
                Tony Jeffree
                  @tonyjeffree56510
                  Posted by Andrew Johnston on 14/06/2012 08:35:18:
                  Well, they were clearly either real or imaginary…
                  Tony
                  PS: I am assuming that people understood the "thou" pun too.
                  #92545
                  Peter G. Shaw
                    @peterg-shaw75338
                    Howard,
                    A question.
                    Are you the Howard Winwood from Sheffield who used (I think) to work with Steve Bass whose line manager was John Seymour during the early '90's? Because if so, I was on the same group at that time. And no, I'm not the EL&P Peter Shaw.
                    If you are, you may wish to converse via private messaging.
                    Peter G. Shaw
                    Edited By Peter G. Shaw on 14/06/2012 15:31:54
                    #92550
                    Sub Mandrel
                      @submandrel
                      Tony,
                      We need to root this out. It's avery bad sin, cos everythings going of at a tangent. Its a prime candidate for some sort of reciprocal arrangement, before everyone is divided into warring fractions.
                      Tony Jeffree
                        @tonyjeffree56510
                        Neil –
                        Too much more of this hyper-bolics & we will all be under the cosh.
                        Tony
                        #92554
                        NJH
                          @njh
                          You lot are all vulgar factions!
                          I no , i no, it's speld rong!
                          #92555
                          Tony Jeffree
                            @tonyjeffree56510
                            either that or you're being deliberately obtuse…
                            #92556
                            NJH
                              @njh
                              Whilst your arguments are complex your ideas are more imaginary than real!
                              #92560
                              Tony Jeffree
                                @tonyjeffree56510
                                Posted by NJH on 15/06/2012 00:44:15:
                                That's ab-surd!
                                Tony
                                #92574
                                NJH
                                  @njh
                                  Now then Tony this thread has drifted so far into the imaginary with all this hyperbole that the original arguement is lost and its functions are now truely all hyperbolics!
                                  N
                                  Edited By NJH on 15/06/2012 10:10:52
                                  Edited By NJH on 15/06/2012 10:11:48
                                  #92576
                                  NJH
                                    @njh
                                    Oh dear Oh dear!!!
                                    My wife has just looked at this thread and says that it all seems to have gone full circle. Who am I to argue – best get on with some useful domestic chore I guess!
                                    N
                                    #92578
                                    Anonymous
                                      Best we stick to the previously mentioned circular transcendental functions then – Andrew
                                      #92579
                                      harold
                                        @harold
                                        It's a just lot of hairy balls…
                                        #92591
                                        Rich2502
                                          @rich2502
                                          I left my expensive Starrett calipers in a damp shed and they died, since then i'm using the Chinese ones there is no difference in the reading but, they are rough as a goats knee, maybe you could stone them to slide smoothly i don't have the inclination to find out.
                                          I had a Victorionox £70 multi tool which i dropped in the canal, it was non magnetic stainless steel, i nearly cried, now i'm using a toy Chinese one of these too.
                                          #92592
                                          Russell Eberhardt
                                            @russelleberhardt48058
                                            Posted by Richard chucklbutty on 15/06/2012 15:54:49:I had a Victorionox £70 multi tool which i dropped in the canal, it was non magnetic stainless steel, i nearly cried, now i'm using a toy Chinese one of these too.
                                            I have a Victorinox Swiss Army Knife which I've had for about 30 years. The spring in the scissors broke so I emailed them to see if they would sell a new spring. They told me to send it back to Switzerland for repair, free of charge, as they are guaranteed for life. Will you get that service from China?
                                            Russell.
