For the displacer gland I, v used a number of methods, starting with carbon impregnated teflon bushes, brass bush with teflon tape, plain brass, bronze, or cast iron. All on stainless shafts, and without lubrication. If made properly there seems little to choose between them.
Would not worry about any small amount of oil thats run into the displacer.
As long as there is no great leaks around the displacer gland, I think it just needs running in, You can use a crank with a large pully to a small pully on the motor if you don;t have a suitable electric motor. I would not use a mini-drill, or other portable drill, although the motor from an old battery drill would be a good start, perhaps with a 6V or so power supply, if you use a plug pack supply make sure its up to it. Ian S C
