Well,, I am not yet fit enough after my fall a week ago to be safe doing any machining, but I have just spent an hour or so fettling the band-saw, guided by the information in the link Oldvelo cites several massages ago,
I printed off the article, edited to remove the writer's (John Pitkin's) blokey chat, to have it at hand. There were differences between the saws he is familiar with, and mine, but not significant.
The drive unit appears all in good condition, which was a relief. No side-play or end-float in the pulley-shaft, a tiny amount of axial movement of the pulley on the shaft – but the grub-screw was loose. The pulley seems to rotate all-square.
So far so good.
Then discovered the spacer between the idler pulley and the block holding its stub-axle is no more than a sawn-off bit of thin-walled steel tube much larger than the axle! That should not matter much, but I modified a fibre-washer to fit (ish) inside it for centralising.
Next, aligned the pulley for slant as far as the machine allows, to tend to pull the blade back to the flange.
Then refitted the blade. Not new as advised as I am down to the last one, but it has cut only one small piece of steel so far.
A precaution I took, I have not seen anyone else mention, was to clamp a board across the bow to restrain the blade if / when it springs off during the servicing. I adjusted the pulleys as he advises, as far my 'Alpine' machine will allow, but still found fitting the blade extremely awkward.
I tensioned the blade as he said – to ring when plucked or tapped. Is that right though?
Then refit the guides – which involves forcing the blade a long way from tangency.
Pitkin advises a small swarf-clearance gap – about 0.01" – between the blade and the adjustable ball-bearing races acting as the outer guides. That made the blade run hopelessly out of line and angle, and try to climb out of the guides.
These machines are made quite well but designed rather crudely; and it's hard to see how they can possibly twist a spring-steel blade though some 45º, off-line, between each pulley and the vice, with any accuracy.
It won't even cut a bit of wood square, vertically, and at the end of the cut the blade stops well away from the cut surface.
My assessment is that guides are too crude to align the blade correctly, so the slightest wear or tiniest error stops anything from working properly. They certainly cannot be adjusted to the blade's natural line.
I cannot decide if the guides are supposed to be several mm inside the tangent, or if the problem is the pulleys have lost that off their radii by wear.
Oddly, this seems to have all occurred only quite recently and rapidly, so possibly it reached a tipping-point in knackered-ness.
I've tried all sorts – set the guides tight or (as Pitkin says) loose, tilting the top pulley more or less, adjusting the edge-guides in or out…
So…
Can this machine be returned to cutting parts for bolted fabrications to sufficient accuracy not to need unintended milling afterwards? (As it probably could in the past.)
Or it a write-off for any but the roughest work?
