Hofmann Rotary table owners?
Home Forums Workshop Tools and Tooling Hofmann Rotary table owners?
  • #401313
    Pete.
      @pete-2
      I just bought a Hofmann 10" rotary table, there's a slight bit of backlash, any owners of one of these confirm how you can adjust this?
      Is that allen screw to the right of the logo have anything to do with it?
      #19279
      Pete.
        @pete-2
        Adjusting backlash
        #401325
        mgnbuk
          @mgnbuk
          UK agent contact details here :
          May be easiest to try them first ? Failing that, the German parent company website also ahs contact details.
          HTH
          Nigel B
          #401332
          Simon Williams 3
            @simonwilliams3
            Posted by Peter F on 19/03/2019 23:42:57:
            Yes.
            The worm is located in an eccentric cartridge, so loosening that screw allows you to turn the (eccentric) worm bearing. Not only does this permit adjustment of the backlash, you can also disengage the worm from the pinion allowing the turntable to revolve freely. Useful for setting up.
            HTH Simon
            #401364
            Phil P
              @philp
              As per what Simon said above, but you will find that a standard Allen key will not fit behind the hand wheel.
              Get yourself a spare Allen key and shorten it so it fits in the space and then leave it there all the time.
              That is what I do on my Hoffmann 8" table. They are a superbly made bit of kit and you will not be dissapointed.
              Phil
              #401422
              Pete.
                @pete-2
                Thanks for the reply Nigel,Simon, thank you for confirming that, Phil yes it seems very nice, well worth an extra 50 quid over buying a new import in my opinion.
                #401427
                Phil P
                  @philp
                  If you have managed to get a Hofmann for only £50 more than an unknown imported one then you really have got a bargain. Well done that man.
                  Mine has the indexing plate attachment rather than the hand-wheel.
                  Phil
