Hobbymat MD65 spindle bearing part numbers
Home Forums Manual machine tools Hobbymat MD65 spindle bearing part numbers
  • #294197
    Jez
      @jez
      Hi,
      Does anyone know the part numbers of the spindle bearings please?
      A friend is rebuilding his Hobbymat MD65 (c 1981 if that makes a difference) and can't see the part number on one of the bearings without removing (and very likely damaging) it.
      One of them is a standard type – he's hoping the other is as well…
      Cheers,
      Jez.
      Jez
        @jez
        #294198
        Chris Evans 6
          @chrisevans6
          Most/all? bearings have a number on them. Without this number you need the sizes inside/outside/thickness, armed with this information go on to something like Simply Bearings or Bearing Boys web page and look up the bearing. Then decide on the most suitable quality/type for the application.
          #294200
          Jez
            @jez
            Hi Chris,
            I haven't seen the assembly, but he tells me that to measure accurately the bearing would have to come off…
            Cheers,
            Jez.
            #294203
            Jez
              @jez
              Hi Chaps,
              Scratch this request – I sort of assumed he'd done the "due diligence" thing and googled it – turns out probably not…
              A quick search shows:
              Front: 32206 (SKF part 32206J2Q)
              Rear: 30305 (SKF part 30305J2)
              Cheers,
              Jez.
