Hints and tips for cutting small(ish) male threads with a die
Home › Forums › Beginners questions › Hints and tips for cutting small(ish) male threads with a die
Viewing 25 posts - 1 through 25 (of 30 total)
  • #428086
    Stuart Bridger
      @stuartbridger82290
      I am fairly sure that the answer here is practice, but would appreciate any advice.
      Trying to cut an M3 x 0.5 thread with a split die on mild steel. Two attempts have failed so far with stripped threads. Adjusting the die, I'm either not getting the thread to start or the thread is so fine that it strips very easily.
      I am using a lathe with a tailstock holder, by hand.
      What major diameter would you recommend starting with? Dead on 3mm?
      Possibly the die is not of best quality, would I better off going for a die that isn't split? If I do carry with a split die, what's the best way to set the size?
      Thanks
      #9851
      Stuart Bridger
        @stuartbridger82290
        #428090
        nigel jones 5
          @nigeljones5
          I dont do metric but thats pretty much 5ba…I wouldnt wind it by hand, I would use the lathe back gear. If its stripping threads you need to open the split die as far as it will go and try a run. Always use lubricant. The dia of rod is dependant upon your application but it is not unusual to aim for a 3/4 thread engagement. For such small threads it is often much easier to buy threaded bar and locate into a tapped hole with loctite. Good luck.
          #428092
          David George 1
            @davidgeorge1
            Hi Stuart to use a tailstock die holder there should be play in the holder to allow the die to expand when as you tighten the centre side screw with the two side screws undone. the centre side screw has a point which pushes the slot wider and makes the die cut less of the thread and then you just nip the other screws to lock the die. after you have cut the thread you try a nut on and if it is to tight loosen the centre screw and tighten the die up and try again. make sure you are using a good cutting lubricant at all times.
            David
            #428097
            old mart
              @oldmart
              As DG1 has already mentioned, it is important that the bore of the diestock is loose enough on the die to allow the die to be opened up for the initial cut. For that small size, about 0.2mm difference in diameters. A slight lead in chamfer helps, as does using the face of the tailstock chuck (with the jaws retracted) to keep the diestock square. A little cutting oil should be used. If you still cannot get a reasonable thread, the die may well be to blame, there are a lot of poor ones out there, and persisting with one of them is like polishing a turd.
              #428101
              Brian G
                @briang
                I find putting a chamfer on the end (with a single point threading tool – please don't judge me, it saves setting the compound) helps start the thread.
                #428104
                Stuart Bridger
                  @stuartbridger82290
                  Thanks for the feedback. I must have a very short memory. Last weekend I successfully cut two threads M2.5 on a 3/32 bar. Apologies for the mixed units 2.5mm is 0.098in on 3/32, 0.09375, so about 4 thou under.
                  So three possibilities, 4-5 thou under is the trick, I got lucky with the die adjustment or the die is a better quality.
                  I will try again with 4-5 thou under the nominal major and see how I get on.
                  #428105
                    Make sure you don't have a 25mm OD die in an imperial 1" holder or 20mm die in a 13/16" holder as it will not be central.
                    I would turn the work to 3mm dead and don't bother with a chamfer just run the lathe at about 75rpm and bring the die holder upto the work by hand (no bar fitted to diestock) and just hold it firm until I have the length needed than let go and turn off. Drop of tapping fluid helps.
                    Edited By JasonB on 08/09/2019 19:10:33
                    #428107
                    HOWARDT
                      @howardt
                      I use size to minus for material and cut with hand turning n the lathe using the tail stock to keep square. Use cutting oil and back off frequently with the die set to maximum open. Turning the material through the die too quickly and not backing off will cause the swarf to strip the thread to a degree. I cut metric down to M2 with no problems in steel and brass.
                      #428110
                      Brian Oldford
                        @brianoldford70365
                        Make several passes under back-gear and don't spare the Trefolex.
                        #428112
                        Anonymous
                          I don't cut many external threads using dies on the centre lathe, but M3 should be no problem. Stock size can be nominal, ie, 3mm or a thou or two less.There shouldn't be any problem starting the die and the thread can be cut in one pass. Given it isn't working there are two likely issues. Since the parentage of the die is reputedly suspect I'd bin it and buy a known make. Second what is the parentage of the mild steel? If the material is unknown bin it and buy known material. Even known materials can be difficult to thread; EN3 has a propensity to tear for instance.
                          I have used a split die on my repetition lathe once, as I'd misplaced the M4 Coventry dies. The M4 threads were cut in one pass at 500rpm in EN1A. So with the right material and cutting tool there should be no problem. I think the M4 die was Dormer.
                          #428114
                          old mart
                            @oldmart
                            Be careful with the amount of diameter reduction you use, these small size threads don't have much to spare. I use these thread charts on the Motalia website, they show the thread depth.
                            Edited By old mart on 08/09/2019 20:34:18
                            #428123
                            IanT
                              @iant
                              Probably most of the main points about die setting have been covered Stuart.
                              One other thought though, if you have a brought-in die holder, just check that the central grub screw has a point (not a flat end) on it or it won't open the die properly (and yes, it took me a while to figure it out).
                              Personally, I don't thread with dies under power – I use a mandrel handle to turn the work. I'm sure it works but it's not what I do myself.
                              For larger diameter fine threads (1/4"/40tpi for instance) I tend to part screw-cut the thread (again using the handle for short/fine threads) to get it going, just finishing with the die. Where a short thread is required (2-3 threads) – I make the thread a bit longer and cut off the surplus after threading – it's much easier that way.
                              I always use material turned to the nominal thread size (not under) – 3mm in your case – and as Brian says, get yourself a tin of the magic green stuff (Trefolex) – it will last you a very long time…and you will eventually get to like the smell…
                              IanT
                              #428158
                              Stuart Bridger
                                @stuartbridger82290
                                Thanks for for all the advice, some really useful stuff there. I have today ordered up some trefolex
                                and a couple of new dies, one split and one solid. I will update further when it arrives and I have had time to experiment.
                                #428163
                                Howi
                                  @howi
                                  some dies will only cut from one side, usually the one with the writing on, been cought out by this before now.
                                  not found the need for split dies on small threads 2, 2.5,3,and 4 mm, no need to go undersize i.e 3mm thread use 3mm material or machine to 3mm, does not matter if slightley under, also helps if there is a slight champher for the die to engage on.
                                  usually turn the lathe by hand using spindle handle and tailstock up against the die holder. you can put slight preasure on the die using the tailstock handle.
                                  ordinary cutting fluid usually used, nothing fancy.
                                  rule number one – nevoer overlook the obvious!
                                  #428178
                                    Here is the way I do it as described earlier.
                                    First make sure your die is the right size for the die holder metric OD will go into imperial but the screws will push them off ctr. I have an imperial diestock so buy imperial OD dies
                                    Writing facing out, I have just nipped up the 3 screws so not spreading and not closing the die. This is Tap & Die's "HQS" quality carbon steel.
                                    Stock is EN1A 3mm nominal which come in at 2.96mm faced off no chamfer.
                                    In Video, ass a drop of tapping fluid, start lathe at a slow speed and push teh die onto th eend of teh rod and hold it there once it bites until you get to the length required and let go. Stop lathe and reverse if you have it, this can be done at higher speed but did not do it here. Clean swarf and test your nuts or part.
                                    I do it this way upto about M8 coarse and 1/2 x 32 in steel, any bigger and it becomes hard to grip the diestock. For larger I will put the tommy bar into the diestock and just turn by hand. I think winding by hand or taking several cuts would slow my output too muchwink
                                    Edited By JasonB on 09/09/2019 10:05:56
                                    #428195
                                      Posted by JasonB on 09/09/2019 10:03:40:
                                      Crikey, you must have a grip like Geoff Capes!
                                      Russell Eberhardt
                                        @russelleberhardt48058
                                        The major diameter of an M3 screw should be just under 2.9 mm so you could start with that diameter. A few thou can make quite a difference at these small sizes. A good lubricant is Rocol RTD compound. I had difficulty with 12 BA (1.3 mm dia.) threads breaking off in the die until I was given a bit of RTD compound to try.
                                        Russell
                                        #428384
                                        Stuart Bridger
                                          @stuartbridger82290
                                          A few observations, no time for practical tests yet
                                          ID of my dieholder is 20.72 mm (a bit bigger than 13/16 – 20.64mm)
                                          Original die is 20.48mm OD
                                          New split die is 20.49mm OD (Tracy Tools)
                                          Both are a slightly loose fit in the holder, without tightening screws – I will most likely make a new holder a bit closer fit.
                                          New solid die (from Arc Euro) is 19.90mm OD – New hold holder to be made
                                          Screws in the die holder are cup point, not cone point, so they need to be replaced
                                          #428385
                                            Tracy's ones sound like nominal 13/16" as does your old one and will be OK in your size holder as you do need a little room should the die need to be opened.
                                            I Know ARC's are Nominal 20mm OD so a new holder will be best for them.
                                            #428890
                                            Howard Lewis
                                              @howardlewis46836
                                              Coming in late no one has mentioned that the Die Holder needs to slide on an arbor. A small thread (under 6mm ) is unlikely to be strong enough to drag a Tailstock along the lathe bed.
                                              +1 for rotating with a mandrel handle, it allows "feel" which may save damage!
                                              Lubrication with Trefolex , Rocol RTD or something similar is taken as read.
                                              Edited By Howard Lewis on 13/09/2019 23:46:20
                                              #428899
                                              Stuart Bridger
                                                @stuartbridger82290
                                                Howard,
                                                I can confirm that the die holder is on a sliding mandrel. I now have all the pieces in place to get this sorted.
                                                Just need some shop time….
                                                #428902
                                                Brian G
                                                  @briang
                                                  Posted by Howard Lewis on 13/09/2019 23:44:20:
                                                  …Lubrication with Trefolex , Rocol RTD or something similar is taken as read…
                                                  Having had a 40 year gap I am still using tallow (not the same batch), and I probably have enough to last me out. Is it worth me switching to one of the newer compounds or tapping fluid?
                                                  #428903
                                                  roy entwistle
                                                    @royentwistle24699
                                                    Brian If tallow still works, why change ?
                                                    Roy
                                                    #428907
                                                      Posted by Brian G on 14/09/2019 08:09:00:
                                                      Not if tallow works for you. Downsides of tallow are it can rot in the workshop – don't get used tallow in a wound – and it's not the most suitable compound available.
                                                      Although tallow is a reasonable lubricant and dirt cheap, it's out-performed by newer compounds containing extreme pressure additives that don't go off and work more reliably. The 'newer compounds' are hardly revolutionary modern ideas – they date back at least a century. Using a solid lubricant whilst tapping might help eject swarf, but I'm not sure tallow is stiff enough to be forced out and take swarf with it; I feel something more waxy is needed.
                                                      Deciding to replace a modern cutting mixture with tallow in hope a traditional material might be better would be a mistake – tallow isn't as effective. Depends on who you are and what you're doing. Taps and dies in my clumsy hands need all the help they can get! That said, faced with an empty spray can, I've successfully tapped threads with paraffin wax and Castrol grease – both worked.
