Help with Adept 2 shaper
Home Forums Workshop Tools and Tooling Help with Adept 2 shaper
  • #20148
    Paul Markey 3
      @paulmarkey3
      Paul Markey 3
        @paulmarkey3
        Hi all,
        I need a bit of help with an Adept no 2 shaper, can anyone who has access to one possibly measure the hole centres on the handle and on the swing link ? Having looked online it would appear that the ram stroke is either 6.250 (lathes.co.uk) or 6.500 (a period advert of the day) the stroke on mine is 5.375 and I wonder if at sometime a new handle or swing link has been made for the shaper or did some Adept no 2's come with 5.375 stroke.
        Thanks in advance , Paul
        #525145
        Ady1
          @ady1
          Handle holes are 4 inches apart on the original handle
          I'm afraid my machine is buried in the deepest corner behind an incredible amount of useful junk so I can't get at the little link bit on the machine
          GL
          #525146
          Paul Markey 3
            @paulmarkey3
            Cheers Ady1, just had a quick measure up and the hole centres on the handle are 3 1/8 and on the link arm 2 7/8 so the handle will need replacing at least .
            Paul
            #525165
            not done it yet
              @notdoneityet
              …. so the handle will need replacing at least .
              Might not. Not seen an adept, but my Alexander had three holes in the handle. Might just need another hole drilling? You might need a much longer handle if you wish to maintain the same mechanical advantage?
              #525179
              Paul Markey 3
                @paulmarkey3
                I had the same thought Ndiy , I think I saw a picture of a Petite rapid lime hand shaper that had 3 holes in the handle I assume to alter the stroke so I may give that a try .
                Paul
                #525184
                ChrisH
                  @chrish
                  Paul, my Adept 2 seems different again in that it has two sets of holes:
                  small link arm, holes at 2.75" & 0.8",
                  Operating arm, holes at 4.425" and 3.5"
                  The first holes quoted are the ones in use and give a ram stroke of 6.25".
                  Obviously the second two would give a shorter stroke but not used or measured it.
                  From centre of pivot pin in small link arm to end of the operating arm is 19.75"
                  Hope this helps,
                  Chris
                  PS – just to clarify the 0.8" hole in the small link arm would give an effective link arm length of approx 2", down from approx 2.75" sounds obvious I know but could have been misconstrued!  All measurements are approx,, measured over the pins/bolts etc.
                  Edited By ChrisH on 06/02/2021 11:07:45
                  #525189
                  Howard Lewis
                    @howardlewis46836
                    Just been out and checked mine.
                    Lever
                    Overall length 24 " Hole centres 3"
                    Link
                    Hole centres 3"
                    HTH
                    #525216
                    Ady1
                      @ady1
                      I'm pretty sure I put extra holes in my linkage to make life easier for certain jobs
                      You don't always need a full stroke, sometimes a shorter stroke with more torque is easier
                      Edited By Ady1 on 06/02/2021 13:05:19
                      #525223
                      Howard Lewis
                        @howardlewis46836
                        TYPO ALERT!
                        Lever Hole centres should read 4",
                        NOT3!
                        Sorry!
                        #525258
                        Paul Markey 3
                          @paulmarkey3
                          Thanks everyone it looks like I need to at the least re-drill the handle for 4 inch centres or there about .
                          Paul
                          #525348
                          Paul Markey 3
                            @paulmarkey3
                            Re drilled the handle tonight at 4 inch centres and the ram stroke is now 6 1/2 inch thanks everyone yes
                            Paul
                            #525424
                            Howard Lewis
                              @howardlewis46836
                              Thanks for the update
                              Glad that you now have it sorted.
