Hello Michael,
I have a Portass Dreadnought which is my second lathe used for odd jobs and one-offs. Having said that it is a very well built and solid machine from the era and in fact I prefer some aspects of it compared to the Myford ML7 I had for about 15 years.
The Portass has a bigger, longer headstock spindle with larger plain bearings compared to the Myford. The tailstock barrel is similarly larger than the Myford with a longer travel. The cross slide is a bit on the short side so I made a new one and fitted sturdy front and rear toolposts.The original top slide can be fitted when required. I also modified the headstock spindle to accept Myford type threaded chucks, faceplates, collet chucks etc. Parts are more easily obtained compared to the Portass thread.
The pulleys are flat belt, using a water pump belt from a Cummins diesel engine. The countershaft pivots on a plate that is tensioned by using a car handbrake lever and ratchet, so that speed changing can be done on the fly.(safety first!). I also extended the change gear plate and added more studs to enable a deeper reduction to the leadscrew when in auto feed cutting.
A good sturdy machine, I hope you enjoy fixing it up.
Mick
