HELP! I a manual for an Elliott 618 surface grinder
Home Forums Manual machine tools HELP! I a manual for an Elliott 618 surface grinder
  • #70482
    Freddybear
      @freddybear
      Hi Folks,
      I have recently aquired an Elliott 618 surface grinder.
      I have no idea about the operartion or maintenance of this particular machine.
      ( For those with an uneasy feeling, dont worry, I used to use bigger versions in industry)
      I would especialy like to know the correct grade of hydraulic oils to use, aswell as which lube oil / grease and were it should go.
      I would very much like to get my hands on a copy of an original manual ( all costs covered), however, any help or information would be gratefully received.
      Freddybear
        @freddybear
        Instruction manual Required
        #70483
        NJH
          @njh
          Hi
          Try Tony
          This is from his site, lathes .co.uk :-
          ELLIOTT Lathes, Milling machines, Shapers, Grinders and Drills. We have very large selection of original
          literature available covering most models. Please e-mail for details. Please phone: 01298-871633 or
          e-mail: manuals@lathes.co.uk
          regards
          Norman
          #71125
          Freddybear
            @freddybear
            Hi, have done, He does have something but not specific to the 618 as far as I gather.
            can anyone else help?
            #77510
            fix-its
              @fix-its
              Hi Freddybear,
              Do you still require info for your Elliot 6-18 surface grinder, if so email me i maybe able to help.
              regards,
              fix-its
              #79121
              Freddybear
                @freddybear
                Manual now obtained. Thanks Brian.
                #79387
                Freddybear
                  @freddybear
                  Hi Folks,
                  Since it seems that there are more than a few owners of Elliott machine tools, such as grinders, mill’s, lathe’s and shaper’s out there, I have started a new yahoo group for all Elliott owners.
                  Hopefully, the owners of these machines can come together and generate a knowledge base for all machines from this manufacturer.
                  Edited By Freddybear on 07/12/2011 11:07:29
