Help finding a rare bolt / machine screw
Home Forums General Questions Help finding a rare bolt / machine screw
  • #272613
    Thomas Gude
      @thomasgude37285
      Hi All,
      The title description just about does it – I am after a an M12 fine thread (1.25) machine screw that is 70mm long and fully threaded. All I can find are bolts that are part threaded. I only need two off
      Does anyone know of any good suppliers of this? Specialist or otherwise.
      Thanks
      (PS Please dont divert this thread into a discussion about the differences between a machine screw and a bolt – thanks)
      Thomas Gude
        @thomasgude37285
        M12 x 1.25 fine, 70mm fully threaded
        #272617
          You might haqve a bit more luck searching for "sets" as the fully threaded hex head screws are often sold by that name though a quick look seems to stop at 50mm long.
          Any chance of threading the rest of a bolt?
          J
          PS 1.25mm pitch is extra fine not fine
          Edited By JasonB on 18/12/2016 20:26:50
          #272618
          mick70
            @mick70
            dunno where you are but try b&d bolts in batley.
            if nowhere near you i can call in get them and get them to you
            #272619
            vintagengineer
              @vintagengineer
              Try Arun Fasteners http://arunfastenerco.uktc.com/Home-index.html. What head do you want, hexagon like a set screw or cap head set screw.
              #272621
              speelwerk
                @speelwerk
                They only have 100 mm, but you can shorten them, Niko.
                https://www.schrauben-shop.de/ArticleDetails.aspx?FORMNUMM=1377&Diameter=12
                Edited By speelwerk on 18/12/2016 20:31:04
                #272632
                Nick_G
                  @nick_g
                  I bought a length of M12 x 1.25 studded rod a little while ago to make adjustable lathe leveling feet.
                  It's a common thread stud size I think for automotive wheel nuts. – Just cut to required length and then you could loctite 638 or weld a nut on to make a full thread bolt.
                  I will try and find a link for some for you.
                  Nick
                  Edit :- Oooops. Just seen the machine screw and not a bolt bit.
                  Edited By Nick_G on 18/12/2016 21:02:43
                  #272642
                  peak4
                    @peak4
                    If you mean hex headed and fully threaded, you could try your local motorcycle shop, The various metric fine threads are often used on Japanese bikes, but sometimes have a different spanner size, maybe 17mm rather than 19mm.
                    Regards Bill
                    #272870
                    Thomas Gude
                      @thomasgude37285
                      Thanks all. Very helpful comments – I will give the links a go and all else failing studding is a good idea.
                      Hex head would be preferable but not overly fussed. Curiously, the bolt that it is replacing (only 40mm) is 18mm across flats on its head which threw me a bit.
