Hi, have recently accuired a 31/2″ lassie , the cylinders are not sealing, there are fitted “o” rings to the cylinders which I intend to replace , I have taken the drive pistons out of the bores no problem but I can’t see an easy way to get at the valve pistons out, I have taken an end cap off piston bore and can see the nuts down inside which locates the piston in the bore but I don’t think I am working from the right end I don’t think the assembly should be dissmantled from within and it won’t come out from the front as it has a domed cover with no apparant fixing, there is no gland on the cover and no means of turning the dome , it has supposedly been built to the words and music of lbsc, would the valve pistons have any seals on them or would they be plain bobbins in the bores ,if no seals are fitted to the piston/ bobbins I see no need to go any further with the stripdown just re “O” ring the drive pistons and re assemble .the cylinders are bronze and the bores are pefect to look at, PS what’s the best “O” ring for resealing the pistons, Malc
