Heavy lifting [of people!] equipment
Home › Forums › Help and Assistance! (Offered or Wanted) › Heavy lifting [of people!] equipment
Viewing 25 posts - 1 through 25 (of 29 total)
  • #624976
    Bill Phinn
      @billphinn90025
      Would anyone be able to tell me whether the lifting apparatus in the link [widely used by ambulance services], which basically consists of a battery-powered compressor connected by airlines to conjoined inflatable cushions, could feasibly be improvised more cheaply, and if so how we'd best go about it? We are sorely in need of such a device.
      https://www.johnpreston.co.uk/mangar-elk-emergency-lifting-cushion-and-airflo-24
      Edited By Bill Phinn on 15/12/2022 00:24:12
      #34129
      Bill Phinn
        @billphinn90025
        #624978
        peak4
          @peak4
          #624979
          Ady1
            @ady1
            various pneumatic widgets might suffice
            #624980
            Bill Phinn
              @billphinn90025
              Posted by peak4 on 15/12/2022 01:03:48:
              Ebay might be a starting point
              https://www.ebay.co.uk/itm/155267284314
              Bill
              Yes, I've scoured the secondhand offerings on ebay. Where the price is affordable, my reservations are usually about how hard the equipment has been worked, and whether the battery is still reasonably capable of holding a charge. I know you said ebay is just a starting point, but that one does look heavily used and has no charger or controller.
              As an alternative to secondhand Mangars I was wondering whether a portable tyre-inflater style compressor and some inflatable pillows or camp beds could be improvised.
              #624981
              Bill Phinn
                @billphinn90025
                Posted by Ady1 on 15/12/2022 01:33:47:
                That does look interesting, Ady.
                #624988
                not done it yet
                  @notdoneityet
                  I note most of these things (apart from very heavy duty vehicle air bags) are termed as ‘emergency’.
                  Personally, I prefer hydraulic rather than pneumatic, particularly for larger lifts (as in ‘higher) as any split would result in a very rapid deflation. So that is my advice – go hydraulic, like most fluid lifting devices around.
                  #624990
                  Robert Atkinson 2
                    @robertatkinson2
                    Hydralic is not suitable for this device. You would need at least 30 liters of fluid, probably more. Not very portable.
                    #624991
                    Sam Longley 1
                      @samlongley1
                      I hope that I have understood what you are after correctly
                      You only need about 3 PSI in these bags & I inflate airbags ( size 2.4 * 1.5 diam) for laying moorings weighing up to 2.5 tonnes with a simple high volume, low pressure pump costing £18-00. iin under 15 minutes. But mine is 240 V & you want 12 V
                      May I suggest 2 options first is an inflatable dinghy pump as sold by marinescene & other yacht chandlers- There are many- Marine scene
                      Or you could just use a simple hand pump as I use for my Avon dinghy. Stirrup pump they do foot operated ones. It is not rocket science to make the adaptors fit You would inflate your bags in a 30 strokes of the pump & for the cost it is worth experimenting. You will not have battery issues to worry about.
                      For batteries one could just get small ones & keep them charged such as a scooter battery. Or go into an RC model shop & buy a couple of LIPO batteries & a charger & get them to explain how to charge & store them. They may even solder the correct connections on for you if you ask.
                      #624992
                      Gary Wooding
                        @garywooding25363
                        Get in touch with your local REMAP panel. We've used pneumatic car jacks for similar purposes, in conjunction with a battery operated dinghy pump as mentioned by Sam. Go to http://www.remap.org.uk to find your local panel and/or make a referral.
                        #624995
                        Mike Poole
                          @mikepoole82104
                          Scroll down to the videos on Bills link and the application of the device and what is required becomes clear.
                          #624997
                          Samsaranda
                            @samsaranda
                            Air bags are eminently suitable for lifting quite heavy items, when I was in the Air Force we used them for lifting large heavy aircraft, they operate on very little Pounds per square inch. Dave W
                            #624998
                            Sam Longley 1
                              @samlongley1
                              Posted by Mike Poole on 15/12/2022 09:17:09:
                              Apologies. I thought that he had the cushions but could not pump them up. Careless of me
                              This forum no longer allows me to edit my post which is a little iritating. Otherwise I would remove it.
                              But if it is air bags that are wanted, then go & see a bouncy castle firm & get some glued up. Then use the pumps that I suggested. They could probably make the bag seat shaped as well, thus putting the patient into a sitting position
                              Edited By Sam Longley 1 on 15/12/2022 09:43:25
                              #625002
                              Ady1
                                @ady1
                                Those cordless airpumps crank out a lot of air at low pressure for dinghys etc
                                You can see them in action on youtube
                                #625006
                                Clive Foster
                                  @clivefoster55965
                                  The issue with improvised systems will be stability.
                                  The proper thing is made as several sections to help control wobbling around as it goes up. Presumably there is something clever inside the bags to justify the outrageous price.
                                  The big car jack bags are seriously squidgy in all directions. They rely on the weight of the car and grip of the un-lifted wheels to stop them flexing their way out.
                                  For people lifting I'd be much happier with the airbag in some sort of parallelogram style frame with a seat on top so the airbag just lifts. The frame gives stability.
                                  #625016
                                  Hopper
                                    @hopper
                                    Those are pretty specialised for lifting people who have fallen and can't get up because they and their carer are ill, elderly, frail etc. Does not seem very safe to try to jury rig something out of a car jack bag. The person could roll off the side of that.
                                    If you are caring for someone at home and they have a fall, you are best to call an ambulance. They will come and help and have the training and gear to do it safely. I only found that out after my late wife had a fall and I just about did my back in lifting her up as a dead weight. Wish I had known it or thought of it on the night.
                                    #625019
                                    Sam Longley 1
                                      @samlongley1
                                      Has the OP considered exactly how he would get the bag under the casualty? Is the intention just to raise their upper body into a sitting position untill help comes, or raise the entire frame. How does the bag help get the person on to their feet without them rolling off & sustaining further injury. Or just as bad – creating undue stress during the process.
                                      Is the intention to make a comfortable bed?- In which case a decent lilo would be just as good. Placed correctly & then inflated might ease the pressure points for a while.
                                      Ambulances can take a long time to arrive.
                                      Edited By Sam Longley 1 on 15/12/2022 11:22:27
                                      #625056
                                      Bill Phinn
                                        @billphinn90025
                                        Many thanks for everyone's replies.
                                        Apologies for the long post, but I think some explanation is necessary.
                                        Yesterday my parents, who, in spite of extreme dementia, both still live in their own home, had three falls between them. They're now falling on average four or five times a week.
                                        My father is 6ft tall, 15 1/2 stone with size 12 feet, shovels for hands and the build of Mick McManus. My mother is lighter, but both are even heavier than a dead weight when you're trying to lift them because their dementia means they often actively resist efforts to help them.
                                        We've summoned an ambulance for them around eight times in the last six months. On only two of those occasions was there any physical injury requiring medical attention. I don't like to have to summon an ambulance for just a fall, partly because of the strain on the NHS and partly because of the interminable waits.
                                        On four of these occasions I cancelled the ambulance after a four or five hour wait [the 999 call handler said it would be around nine hours] because I was able to get help from a third family member who lives 7 miles way. Clearly, I can't depend on that help from non-resident family 24 hours a day.
                                        My wife and myself can usually get my mother to her feet if she falls, but my father is another matter. I've managed to get him off the floor entirely on my own three times, but each occasion was harder than the last, and I know my limits.
                                        Acting on advice from a family friend, we recently subscribed [after enormous efforts, involving a City Councillor, at getting the very sluggish ball rolling] to a local authority-led Community Response service, which is a paying service and will send out teams with the Mangar gear to do the lifting instead of the NHS.
                                        We've used this service twice already in the last week and we've only been enrolled for a week. The total number of falls we've had to deal with in the last week is actually five, though, so we're trying to use the service sparingly.
                                        Even so we were told yesterday after my father had a second fall while the response team were still here packing away their gear that if we get more than one lift in a day from them we can't call them out again that day and will need to summon an ambulance for assistance. This means we would be back to square one, with nine-hour [plus?] waits ahead of us.
                                        Hopefully this explains my need for lifting gear of my own.
                                        I'll respond to some of the suggestions raised in a later post.
                                        #625059
                                        Sam Longley 1
                                          @samlongley1
                                          Thinking differently would not a demountable frame 2.2 M tall a bit like a child's swing with a small electric hoist work?
                                          4 stainless steel 25mm diam legs & a short cross bar with 4 sockets. Just put it together over them & the hoist could be on 1 leg with a dynema cord going up over a light pulley clipped to the top
                                          If they fall over a lot, have one permanently welded up with 4 small castors & just move it over them.
                                          Lift the casualty with a webbing strop under the arms.
                                          Edited By Sam Longley 1 on 15/12/2022 15:21:29
                                          #625060
                                          Ady1
                                            @ady1
                                            He should be in a wheelchair now IMO, before something gets badly broken
                                            The big guys always struggle with old age, it's great when you're young but it's the little skinny runty guys who thrive in old age, (I used to do residential nursing home stuff)
                                            I'm managing my own folks too ATM, but there's 3 of us to spread the load about
                                            edit: back to the thread
                                            Look for any care homes closing down locally, the increase in care costs means there will be closures and that means spare equipment looking for a good home
                                            Another possibility, a modified car engine hoist?
                                            Edited By Ady1 on 15/12/2022 15:26:43
                                            #625068
                                            HOWARDT
                                              @howardt
                                              When my father was alive I had a similar problem, he used a wheelchair to get around his bungalow but would fall at times either from a chair or bed and end up lying on the floor overnight. As he only had bad legs and couldn't use them to lift himself, he needed me to lift him onto a seat. I thought of this problem and the main difficulty is getting something under them initially to use as a support to lift. Most places that have to do this use two people, one either side to lift under the arms, difficult for one person particularly if the person struggles. Probably something along the lines of a screw lift chair with bars which could be slipped under a person even without lifting them to do so would work. Air cushions would be difficult to slide under a person unless you had room to roll them to the side and back, again difficult with a non co-operative one. Maybe there is something out there in the medical apparatus field that would work but I think most places that would have a use for it just use two people (or more0.
                                              #625091
                                              Bill Phinn
                                                @billphinn90025
                                                Thanks again for your suggestions.
                                                NDIY, I initially rigged up a kind of low profile swing seat that hung below a Clarke Strong Arm lifting leveller dangling from my engine hoist, but I dismantled it last week without having used it because two days after creating it the Community Response service was activated. I may press the swing seat back into use. Obviously my use of it will be restricted by where I can and can’t get an engine hoist in the house.
                                                Sam, we have a pump for inflating air beds but no dinghy pump. I’ll try the first and if no luck investigate the second. Unfortunately, I won’t get the time to leave the house and view products in person to assess and discuss their suitability.
                                                The intention is very definitely to get the patient on his feet, not to make him comfortable lying down. We can make him comfortable on the floor with yoga mats et al. but we can’t carry on with the business of living for long unless we can stand him up to change, feed, bathe him etc.
                                                Could you provide me with an image of the 4 legged arrangement you envisage for the electric hoist? The problem with lifting under the arms [the method we relied on initially] is that as soon as you start to take my father’s weight under his armpits he throws his arms in the air like a seagull getting airborne. He has no idea what you’re doing to him; he only knows he must resist it at all costs.
                                                Sam and Howard, getting the deflated bag under the patient isn’t easy but it’s by no means the hardest part of the task. You basically have to tilt the patient all the way to one side, slide under part way, tilt the patient over the other way, then follow the same procedure. The lift itself using the Mangar airbags isn't child's play; it requires two people either side to stabilize the patient and stop him from falling off the slowly expanding bags.
                                                Gary, I’ve left a message with Remap. Hopefully they’ll return the call.
                                                Ady, I’ve been considering a different kind of Aldi compressor for some time for general purposes. Since I don’t have any Aldi batteries for their cordless range, do you think this mains compressor would be equally suitable as the one in your link?
                                                #625132
                                                Gary Wooding
                                                  @garywooding25363
                                                  Bill: I will be very surprised if Remap don't respond, but PM me if they don't.
                                                  #625134
                                                  KWIL
                                                    @kwil
                                                    I bought a Mangar bathing lift in 2017 was £385 (no Vat payable as disabled use) they are now £429.95 (no Vat) from Mobilitysmart.co.uk
                                                    Good device works in bath where the sides are stablised by the bath itself. Not in a bath you just need to hold the person to control any wobble. Not cheap but……
                                                    #625149
                                                    Hopper
                                                      @hopper
                                                      Bill, having nursed my late wife through her final years of young-onset Alzheimer's (dementia) at home, including a number of falls — but not the frequency you are talking about — I can relate. And I just can't imagine how you are coping virtually on your own with this situation of two dementia patients falling regularly.
                                                      Here in Australia we have government programs designed to keep people living at home rather than moving into a nursing home, so they pay for the kind of assistance you need. Is there no equivalent in the UK? Have you spoken to any kind of dementia support group or social worker to find out what kind of support might be available? There must be some kind of national Alzheimer's support association that can steer you toward such help.
                                                      Two dementia patients living on their own and falling over regularly relying on the help of a relative residing outside their home is not a sustainable situation. It is a degenerative disease so things get progressively worse, usually more quickly than you anticipate. The time to seek help is before you need it, not after. Things can get overwhelming fast.
                                                      Your biggest problem is not getting Mum and Dad back up off the ground, but what is inevitably going to happen to them on the way down. Broken hips, particularly among older women who have brittle bones due to hormonal issues, are almost guaranteed to happen. At that age, they usually never recover from the injury. And one head blow on a sink or corner of a table, or the floor could be even more catastrophic.
                                                      I don't mean to be alarmist, but really you need help and need it fast. (Been there, done that.)
                                                      Hopefully others on here with experience of such things in the UK will be able to offer suggestions on whom to contact for support in your time of need.
                                                      And it may well be that they have reached the stage where living at home alone is no longer sustainable for Mum and Dad. A tough call to make, and one you should be able to get some kind of professional help to make, usually in the form of an occupational therapist or similar's assessment of their capabilities and circumstances.
                                                      Reaching out for practical help with the lifting issues on this forum was a good start, but please look at reaching out through the medical and social support services for a much broader range of help that you are rapidly heading towards needing.
                                                      From the net, this might be a place to start (if you haven't already of course)
                                                      Alzheimer's Society – the Dementia Connect Service for England, Wales and Northern Ireland can be contacted on 0333 150 3456 or email [email protected]. The helpline offers information, support, guidance and signposting to other appropriate organisations.
                                                      They also have a list of available support on their website here Alzheimers.org.uk click on "Get Support" at the top of the page for more information.
                                                      Forgive me if you have already been through all this stuff to no avail, but your situation sounds just awful to me and I am just hoping you might be able to get the help you so desperately need.
                                                      Edited By Hopper on 16/12/2022 12:37:44
                                                      Edited By Hopper on 16/12/2022 12:41:08
                                                      Edited By Hopper on 16/12/2022 12:41:45
