Hardening screws for tool post
Home Forums Beginners questions Hardening screws for tool post
  • #7158
    Wolfie
      @wolfie
      #152417
      Wolfie
        @wolfie
        I'm thinking of making a bespoke tool post to hold my parting tool.
        Do I need to harden teh screws that hold the tool? Occurs to me that if I don't they will just mush up at the business end.
        #152423
        jason udall
          @jasonudall57142
          Harden or not…use cap heads/grub screws..hard before you start…
          It can also be argued to use over size screws and leave soft..but reduce contact point to avoid removal probs.
          #152427
          Ady1
            @ady1
            I use those m10 high tensile allen socket bolts in different lengths with no problems
            Usually 25mm for a tool holder
            The "weak" point IMO is the thread cut in the holder itself
            The bolts are very tough
            Edited By Ady1 on 13/05/2014 22:38:44
            #152430
            WALLACE
              @wallace
              I usually stick a shim ofscrap ally between the bolts and the tool to avoid marking it. And I think the bolts have the threads turned away slightly so if they do get mushroomed, they can still be unscrewed from the holder.
              W.
              #152470
                For my QCTP I bought a bag of stainless M5 cap-head screws from Screwfix. One advantage of these is the end is slightly chamfered as they are supplied, so distortion of the end is not an issue.
                JOOI, I took a random M6 from a bag yesterday, and found it was oversize and wouldn't fit a tapped hole. A second screw went straight in.
                #152490
                JohnF
                  @johnf59703
                  One word of caution regarding fasteners, whilst the imported and economical Allen screws are probably good enough for some applications they are no where near the strength and quality of say Unbrako fasteners.
                  I bought a selection of imported ones from J & L one MSC and they are OK , I have used them for many jobs but they are next two useless as replacements in my Dickson tool holders so I purchased Unbrako for these.
                  Just my observations and thoughts.
