Grinding Wheel Blotters
Home Forums General Questions Grinding Wheel Blotters
Viewing 25 posts - 1 through 25 (of 28 total)
  • #296752
    terry simpson 1
      @terrysimpson1
      Having the need to remove and remount both grinding wheels on my Tool and Cutter Grinder I find that the manufacturer fitted paper blotter on each wheel has become, shall we say unusable again (knackered otherwise). As it is impossible to buy new paper pads what other materials have our brethren used to soften the compressing forces of the spindle clamping devices on the grinding wheel.
      Have thought about actual blotting paper from the likes of Ryman or Smiths but apparently wet ink as was known is not used nowadays.
      I was actually advised to try some very fine sand to dry the ink as in Dickens time.
      #25219
      terry simpson 1
        @terrysimpson1
        #296756
        David George 1
          @davidgeorge1
          Hi Terry
          I have used cereal box card as any soft thick card is enough to take up the irregularities and give grip to the driving washers safely.
          David
          #296760
          Ian P
            @ianp
            Terry I think you would have a difficult time getting sand to stay in place whilst fitting the grinding wheel!
            I don think you need actual blotting paper, any thin cardboard of thick paper would be fine.
            Ian P
            #296775
            charadam
              @charadam
              I've found pub beer mats ideal. And I enjoy collecting them!
              #296777
              Nicholas Farr
                @nicholasfarr14254
                Hi, well Ryman's have it on their web site **LINK**
                Regards Nick/
                #296783
                  Cereal boxes are what I was going to suggest, more like the actual thing than real blotting paper.
                  Robbo
                    @robbo
                    Any soft single layer (not corrugated) cardboard will do.
                    #296804
                    Hopper
                      @hopper
                      +1 on Corn Flakes boxes.
                      #296821
                        A model engineer has been found face-down in a bowl of cornflakes.
                        Police suspect a cereal killer.
                        #296826
                        ega
                          @ega
                          LHS opined that a wheel assembled without blotters would inevitable burst in time.
                          #296839
                          John Haine
                            @johnhaine32865
                            It's always called blotting paper but I suspect that in times past that was something that MEs had which seemed similar to what the makers fitted. But when I've bought new wheels what is actually fitted seems more like cereal box cardboard to me!
                            #296840
                            ega
                              @ega
                              The blotter also provides a space for the wheel designation and MOS – often covered by the flange, however.
                              I find that the porous cardboard promotes rusting of the flange and have lately made these of stainless material.
                              #296866
                              Nicholas Farr
                                @nicholasfarr14254
                                Hi, I agree that cardboard is a suitable blotter, but there are regulations that cover these, especially in a work environment. A free copy of all the regulations is available **LINK** it is worth reading, although most of it is probably not needed for the majority of home users, but there is a paragraph about blotters.
                                Regards Nick.
                                #296869
                                Antony Powell
                                  @antonypowell28169
                                  How many of you have Abrasive wheels regulations training for changing grind wheels /discs/ stones at home ?
                                  #296874
                                    Posted by Antony Powell on 07/05/2017 14:24:39:
                                    And how many of us get the workshop kettle PAT tested?
                                      Posted by Neil Wyatt on 07/05/2017 09:48:11:
                                      Who will have to do Porridge…
                                      #296889
                                      Nicholas Farr
                                        @nicholasfarr14254
                                        Hi, while the regulations as such to home use doesn't apply, manufacturers have to supply the machines increasingly to comply with them. I have had the training for them three times now for my work, as the 1970 regs have been superseded by PUWER98 **LINK**
                                        Safety matters with abrasive wheels at home also, because the same injuries can occur by misjudgement of the issues.
                                        I've no intention of belittling anyone, but injuries from these can be quite horrific even in home use.
                                        Regards Nick.
                                        #296891
                                        Nicholas Farr
                                          @nicholasfarr14254
                                          Posted by SillyOldDuffer on 07/05/2017 16:05:59:
                                          Hi, I think it could be Co-Co, Pops. smiley
                                          Regards Nick.
                                          Edited By Nicholas Farr on 07/05/2017 17:06:15
                                          #296893
                                          mark costello 1
                                            @markcostello1
                                            I think it was Tony the Tiger with Captain Crunch in the cupboard with a Snap, Crackle and Pop.
                                            #296910
                                              Posted by mark costello 1 on 07/05/2017 16:59:23:
                                              I suppose Captain Crunch has Honey Nuts? (Even I think that's dreadful. Who started this breakfast themed waffle?)
                                              #296913
                                              Brian H
                                                @brianh50089
                                                BrianPosted by Neil Wyatt on 07/05/2017 14:54:18:
                                                I used to be the Quality Manager at a small (non engineering company) and it was decided (by the government, I believe) to insist that all portable equipment should be PAT tested and testing was a quality responsibility so guess who ended up doing it?? A kettle was picked for demonstration and it failed because there was no water in it and the water was needed to complete the electrical circuit!
                                                #297067
                                                Tractor man
                                                  @tractorman
                                                  On the breakfast theme CNC only stands for one thing at our house and it’s crunchy but cornflakes. Bah humbug….
                                                  #297071
                                                  David Jupp
                                                    @davidjupp51506
                                                    Re PAT testing – the HSE actually put out very sensible guidance on what needs to be done. If more people read the guidance and did basic visual inspection themselves, there'd be a lot less people scuttling round with those fancy yellow testers and putting stickers on things that don't even need to be tested.
                                                    #297117
                                                    Tractor man
                                                      @tractorman
                                                      Having consulted the said book obtained from HSE I can provide the following data on bloggers.
                                                      They should be of a compressible material usually cardboard between 0.2 and 1.0mm thick. They should be an easy fit on the shaft and slightly larger than the mounting flanges.
                                                      Before fitting they should be checked for wrinkles. Finally a blotter can serve as a label, but a label cannot act as a blotter.
                                                      Basically cereal boxes will do. Mick
