Gear set up on db10g for .9 thread
Home Forums Beginners questions Gear set up on db10g for .9 thread
Viewing 21 posts - 1 through 21 (of 21 total)
  • #6000
    Stephen Gray 2
      @stephengray2
      Stephen Gray 2
        @stephengray2
        Hi I need to cut a 9.5x.9 mm internal thread on some brass I have a db10g lathe but the threading table only shows gearing for 8.8 any ideas
        #86182
          It would help us if you say if the machine has a metric or imperial lead screw and what pitch that is.
          J
          Are you actually cutting M9.5x 0.9 or trying to cut 1/8" BSP which is 9.7ish x 0.91ish
          Edited By JasonB on 29/02/2012 20:20:15
          #86185
          Stephen Gray 2
            @stephengray2
            Hi lathe is metric the pitch for the thread is .9 according to the thread gage
            #86189
              But have you tried a BSP 28t thread gauge on it as I doubt you could see 0.007mm difference with the naked eye.
              0.9 is a very unusual metric pitch and 9.5mm dia is also a bit of an oddity thats why I feel its 1/8" BSP which is 28tpi and 0.383" dia which allowing for tollerance on teh OD could just come in at your 9.5mm
              #86191
              Stephen Gray 2
                @stephengray2
                Don't have a bsp gage but I think your right just had a search,
                the threads on a presher gage which come as bsp 1/4 or 1/8 will have a search for a tap .
                Thanks
                #86195
                Les Jones 1
                  @lesjones1
                  Hi Steven,
                  I have a DB10 G but it does not show a setting for 8.8 mm ( Or 0.88 mm) so the gearing must be different. The first gearing is a fixed ratio of 0.75 (A 45 tooth driving a 60 tooth)
                  The ratios available in the gearbox are these
                  A B C
                  I 0.7 1.75 0.875
                  II 0.4 1.00 0.5
                  III 1.00 2.5 1.25
                  The leadscrew is 2mm pitch
                  So with 1:1 ratio in the change gears the pitch of the thread cut would be 1.5 times these values (0.75 * 2 mm leadscrew pitch)
                  So gearbox setting A II would cut a 0.6 mm pitch.
                  You want 0.9 mm pitch so you need to gear up by 1.5. If you have the same change wheels as I have you will have a 40 tooth and a 60 tooth. If you arrange to have the 60 toothe driving the 40 tooth it should cut 0.9 mm pitch
                  Les.
                  Edited By Les Jones 1 on 29/02/2012 21:34:52
                  #86197
                  Les Jones 1
                    @lesjones1
                    Hi Steven,
                    After looking at other replies I realise I made an assumption that I had no information to support. I assumed it was the metric version of the lathe like mine. If yours is imperial ignore all the above information.
                    Les.
                    #86198
                    Stephen Gray 2
                      @stephengray2
                      Hi les just checked the lathe for 0.88 the gearing is
                      H. 45
                      I
                      70 80
                      I
                      60 H speed setting C
                      #86202
                      Les Jones 1
                        @lesjones1
                        Hi Steven,
                        Your lathe must be a different version of the DB10 G than mine. I do not have a 70 tooth change wheel.
                        Les.
                        Edited By Les Jones 1 on 29/02/2012 22:30:26
                        #86213
                        Ady1
                          @ady1
                          What tpi are you after??
                          It all boils down to tpi, 25.4 for a 1mm thread etc
                          If you can give me the tpi and your gears, plus your leadscrew tpi, I can find your perfect or nearest combination.
                          (Nearest combinations are a problem because the right tooth moves around)
                          Edited By Ady1 on 29/02/2012 23:50:28
                          #86215
                          Ady1
                            @ady1
                            Metric what? 2mm? You havent even told us what your leadscrew pitch is yet.
                            To help we need
                            Leadscrew pitch. 2mm?
                            Thread pitch 9mm? 9.5mm?
                            It doesn's matter whether the thread is cut on 9.5 inches or 9.5 metres, but we need the thread pitch and the leadscrew pitch.
                            Then I need your gears, and your gearing configuration.
                            Most lathes are 1-2-2-1 headstock-compound-compound-leadscrew
                            I can crank through 50 million combinations and permutations in about 3 minutes…but only if I know what you have to play with
                            Edited By Ady1 on 01/03/2012 00:19:05
                            #86216
                            Ady1
                              @ady1
                              Got a 28tpi match for 0.9mm
                              2mm leadscrew is 12.7 tpi
                              with 20.25.30 35.40.45.50.55.60.65.70.80 and 63 the nearest is
                              20 45/50 63/50 and 50
                              which gives an error of 0.00176336, about 0.2%
                              So you're going to need to have a few weird number gears to have a hope of an exact match.
                              #86217
                              Ady1
                                @ady1
                                Got nowhere with an exact match on a metric 12.7tpi, up to 85 million iterations.
                                A doddle with 8tpi though, loads of combinations
                                20.20/20.20/35.40 etc etc etc
                                #86223
                                Ady1
                                  @ady1
                                  25.4/0.9 is 28.222 tpi
                                  Tried a "devo max" (scottish colloquialism)
                                  12.7tpi
                                  gears 19.20.21.22.25.30.35.40.43.45.47.49.50.55.60.63.65.70.73.80
                                  closest is:
                                  19 50/47 60/49 55 for an error of 0.01491%
                                  #86226
                                    ADY you need to bear in mind that the driver is fixed on these lathes so just punching the available rations into a computer will not work. You need to take account of teh fixed gear and then work with whats left.
                                    Does it have to be screwcut, can you not just use a 1/8" Tap?
                                    J
                                    #86232
                                    Ian S C
                                      @iansc
                                      Proberbly best with a tap, because its proberbly BSP tapered thread which is a little difficult to do on the lathe, maybe not impossible, but I don't know how it's done. The only 1/8 BSP tap that I'v bought cost about $NZ40, lucky me I was'nt paying for it, a friend needed it. A few yrars later I got one of my own, much better price 000, very handy. Ian S C
                                      #86235
                                      Les Jones 1
                                        @lesjones1
                                        Hi Ady,
                                        I can feel your frustration. It was this that made me start the thread "Forum niggles". This is a case where information of what the Item was to be used for would probably point towards a BSP thread. I cannot work out from Stevens description of the settings for 0.88 (Unknown units) how the geabox and change wheels are set up. My table of geabox ratios did not come out very clearly as its format was changed between typing and display of my reply. As you are probably not familiar with the DB10G gearbox it has two knobs one marked A, B , C the other I, II, III This give 9 ratios but two are the same ratio. I agree that a tap is the most sensible solution.
                                        Les.
                                        #86251
                                        Stephen Gray 2
                                          @stephengray2
                                          Problem solved Managed to get reducer 1/4 to 1/8
                                          just for interest I uploaded pics of front of the lathe why it has metric and imperial I don't know only had the lathe for 2 weeks and the manual lost in the post?
                                          #86255
                                            That looks more like a DB10VS than a G
                                            In which case it will cut metric and imperial pitches though the imperial may be a fraction off.
                                            If you put on the changewheels as per the 28tpi on the imperial chart you will get your 1/8" BSP threadsmiley
                                            J
                                            #86262
                                            Les Jones 1
                                              @lesjones1
                                              Hi Steven,
                                              Your lathe is the more modern version with variable speed than mine but the screwcutting setup is also different. Mine is only designed for metric screwcutting where on yours the gearbox provides the conversion ratio between metric and imperial. On mine I need to try to work out a sequence of gears to give an approximation to the imperial pitch I require. This is why I had worked out the ratios of the gearbox on my lathe. From your picture I now understand what the "H" means. It means that a spacer is used in that position so the first 45 tooth gear does not influence the gear ratio. It is just an idler to make up space. The first ratio will be the number of teeth on the spindle gear to the 80 tooth gear.
                                              Les.
