I'm about to cut some change wheels for my lathe, a Leinen L4ZS as I don't have the appropriate full set to cut the threads I need for a particular job. This will be the first time I have ever cut gears.
The gears are 1.25 MOD and I have bought the gear cutter for the job.
I'm thinking of cutting the 15mm thick gears on my Centec 2A mill with the axis horizontal and the cutter in the vertical head.
The full depth of the teeth is a little less than 3 mm.
My question is should I be thinking of cutting the teeth in one pass with a fine feed rate or should I consider several passes.
I could also do the job with the cutter mounted on a horizontal spindle.
I'm also thinking that I need to complete my powered feed project first.
What advice can you offer?
