My machine is a RF25, for which I made an "extractorr" for tooling held in the 3MT spindle by the drawbar.
The nut holding the pulley to the spindle has a left hand thread. Remove and turn down the underside, to a suitable diameter, for just over the thickness of the plate mentioned below (not more than half the thickness of the nut) .
Take a piece of 1/4" or 6mm plate and bore out to just fit over the recently turned diameter on the nut.
Tap two holes, equally spaced about the centreline, Now, M6 would be the preferred, instead of my 1/4 BSF.
Place the plate on the diameter of the nut, refit it to the spindle, and tighten the nut.
Take another piece of plate, the same size as the first, and drill two holes, clearance for the thread chosen for the now captive plate, on the same centres.
Tap a hole in the centre of this plate, (I used 1/4 BSF). M6 would be more applicable nowadays.
Take / make two suitable long setscrews (I used 1/4 BSF studding with knurled "nuts" Loctited into place) and drop through the clearance holes. To keep the setscrews captive, a nut can be screwed on, under the plate.
Screw a suitable setscrew into the central tapping, to act as a forcing screw.
Slacken the drawbar by half to one turn..
Place the plate over the drawbar, and hand tighten the setscrews, equally, into the tappings in the captive plate.
Tighten the central forcing screw.
The Morse taper should now free. If it doesn't free off, a light tap on the head of the forcing screw should do the trick, avoiding the need to belabour the spindle bearings.
Remove the "extractor", and put away ready for next time.
Unscrew drawbar and remove tooling from the spindle.
Hope that this helps.
