FreeCAD v1.0 tutorials
Home Forums CAD – Technical drawing & design FreeCAD v1.0 tutorials
Viewing 25 posts - 26 through 50 (of 51 total)
  • #796937
      On SillyOldDuffer Said:
      […] The difference is presentational:  though the task panel is on the left it still works as I describe.  Click on XZ-plane and then the OK button. […] Reconfiguring the display is liable to confuse beginners! Advanced users can change it if they want.     Possibly the mac version is tweaked on delivery because the packager likes it that way, and didn’t realise the layout might disconcert beginners following a tutorial.    […]
      Thanks for doing that, Dave …
      I actually changed my screen layout specifically on the advice in the video tutorial; in the hope of making it easier to follow.
      Incidentally: There is no problem with ‘real estate’ … I am sitting fairly close to a 32″ monitor, and the drawing area is adequate.
        Extra thanks to Keith and Jason, whose posts I missed whilst faffing-about !
        John Haine
          @johnhaine32865
          Thanks for the Linux confirmation and that it will work on a Pi.  Is that the 500?
          #796955
            A first interesting grab, for Dave
            This notification appears every time that FreeCAD is opened on the Mac
            Screenshot 2025-05-08 at 14.37.40
            It’s a known issue, and of course the lost milliseconds will vary according to the spec of the machine.
            … I have no intention of dabbling with Font substitutions !!
            Roger Woollett
              @rogerwoollett53105
              I have a Pi5 8GB with the Raspberry NVMe SSD so probably a little faster than the 500 but I think it should be fine on that. It is usable on a Pi4 but the Pi5 is noticeably better. I also have a 27 inch 2560×1460 screen which helps a lot.
              #797014
              John Haine
                @johnhaine32865
                Thanks Roger.  I’m intending to divorce myself from Microsoft and an option is to use a Pi5 as the regular “desktop”.
                #797018
                Bazyle
                  @bazyle
                  By the way just remembered that there is a version of Freecad developed by a commercial enterprise (but still free versions) that is said to have a ‘better’ user interface which might be of interest to some. Unhelpfully I can’t remember the name at the moment. Probably mentioned on one of the previous threads on CAD.
                  #797020
                  Andy Stopford
                    @andystopford50521
                    It was called Ondsel and is now no more. Some of the UI changes have apparently been incorporated into FreeCAD 1.x:
                    https://ondsel.com/blog/goodbye/
                    #797023
                    Roger Woollett
                      @rogerwoollett53105
                      I do exactly that. Not used my Windows box since I bought the Pi5.
                      #797040
                      John Haine
                        @johnhaine32865
                        That’s encouraging!
                        #797086
                          As proof of learning !
                          IMG_0764
                          The perspective is rather misleading, but this stepped tube has a constant diameter almost to the bottom, where the iris aperture is formed by the [virtual] 118° tip of the drill.
                          An enormously expensive little bit of plastic tube, thus far … but I’m on the way
                          Drawn in FreeCAD, Imported into Bambu Studio, printed on the P1S
                            This little thing is the result  of a lot of work, a lot of mistakes, and a lot of lessons learned today:
                            IMG_0771
                            Nominal dimensions are:
                            Major OD= 27.1mm … Length =6mm
                            Minor OD =25.1mm … Length =6mm
                            Bore = 24.1mm … Length =11.6mm
                            This leaves a thin diaphragm on the end, as a good base for printing, which will be removed manually.
                            In case it’s not obvious ; it’s a simple adapter to mount a small camera.
                            The general principle will serve me well, now I know how to model it !
                            Per Ardua ad Astra
                            #797410
                              On Russell Eberhardt Said:
                              I’ve always found MangJelly’s Youtube tutorials to be very good.  […]
                              Thanks again, Russell … I like his style
                              Keith Petley
                                @keithpetley53472
                                Hi Michael,
                                The adapter is looking like good progress. If you didn’t want to put the support diaphragm in the CAD model you can add it in the slicer (BambuStudio). Under the “Others” tab change there is a setting called Brim Type which controls the addition of a single layer around the part to act as a base. It’s probably set to “auto”, but I like to explicitly set it as needed.
                                Doing it in the slicer keeps the CAD model the same as the final part and a single layer brim is easier to peel off.
                                Keith
                                #797508
                                  Thanks for mentioning that, Keith
                                  I have to admit that my solution was ‘expedient’
                                  … I did try adding a Brim, but obviously did something very wrong and produced this unholy mess:
                                  IMG_0766
                                  Thank heavens for the monitoring camera !
                                  #797513
                                  Keith Petley
                                    @keithpetley53472
                                    Not easy to diagnose from a photo, but the outer ring appears to be still attached to the bed and the rest has lifted.
                                    Is the outer ring actually a brim or is it a skirt? (Skirts don’t attach to the model but simply lay down filament on the bed around the model). If it is a brim is the “Brim-object gap” set – if so reduced it to zero and try again. It sets a small gap between the brim and the object – meant to make it easier to remove – but it also tends to lose its grip on the object during printing.
                                    #797521
                                      Aha !  … thanks again Keith … I think it was a Skirt
                                      Must check the terminology more carefully
                                        The better news is that I have now tweaked the various dimensions, and the latest version of little adapter is a snug fit in both items.
                                        This qualifies as ‘proof of concept’ for me.
                                          All you clever 3D modellers may well laugh, but this video has probably saved my sanity:
                                          https://youtu.be/RVqxMeVGVlk?feature=shared
                                          I have spent hours today, simply trying to fully Constrain a Rectangle, and at last here’s someone who actually explains and demonstrates the process.
                                          Speedy Builder5
                                            @speedybuilder5
                                            I am running freeCAD on a MacBook AIR, the Tutorial1 has more icons on the toolbar than when I run freeCAD on my laptop. Is this because the laptop screen is smaller than a large display ?
                                            FreeCAD Tutorial LargeMy FreeCAD screen Large
                                            #797941
                                              FreeCAD seems to be so “Customisable” that almost anything is possible !
                                                That and the Icon size together. Try smaller.  Icon size is changed from Edit->Preferences->General
                                                icons
                                                Michael said that FreeCAD is customisable such that almost anything is possible.  True!  The facility is for advanced users, best avoided by beginners, because configuration is a complex learning curve in itself.  My advice, avoid messing with the display until basic modelling is conquered.
                                                Most CAD programs are highly customisable and it can be painful!  SolidEdge has a nasty habit of turning panes off for no apparent reason.   Not difficult to turn back on when you know how but cost me an afternoon the first time it happened…
                                                Another problem learning FreeCAD is it supports about 30 workbenches, and it’s not obvious which of them support Mechanical Engineering.  FreeCAD 1.0 reduces the fog by coming with a simplified list of workbenches, so not quite so easy to get lost in hyperspace!  But still not clear that almost all Mechanical Engineering is done in “Part Design”, possibly supplemented by Part, Sketcher, Techdraw, Gears and Fasteners.
                                                Bazyle
                                                  @bazyle
                                                  A point about the workbenches – they are not different programs. They are all one bench like the bench in your garage with a pile of tools on it and the model you are working on in the middle. When you switch to another workbench what you are actually doing is just like in your garage. You are putting all the tools neatly back in the toolbox and bringing out a new set but the model is still sitting on the bench all the time. Advanced users can actually make their own workbenches with a selection of favourite tools. However the workbenches offered a just a selection of the most likely useful ones.
                                                  I mention this not to suggest you customise things but to hopefully make it less frightening that there are lots of different programs you have to learn.
                                                  #798095
                                                    Workbenches can be almost anything.  As FreeCAD is open source, developers can link or integrate code as they see fit.  Allowing FreeCAD to build-in or externalise almost anything is powerful and encourages experimentation, but the freedom reduces consistency.   OpenSCAD isn’t like Part Design and gmsh is different from both.  Look, feel and workflow can all vary.
                                                    My advice, Mechanical Engineers should explore FreeCAD’s other workbenches only after Part Design makes reasonable sense.  It 3D models parts in a well established sketch-on-face way and then straightforwardly links to CAM for 3D-printing and CNC.
                                                    Speedy Builder5
                                                      @speedybuilder5
                                                      Thanks for the suggestions re – toolbar icons.  I changed the size to small, but it made no difference. Fortunately, all these icons that are not on the freeCAD toolbar can be found on the Apple toolbar – SKETCH dropdown.
                                                      Bob
                                                      Sketch dropdown
