Form tool to cut big end / main crank bearings.
Home Forums Beginners questions Form tool to cut big end / main crank bearings.
  • #388735
    David K
      @davidk77137
      I have roughed out an inline 4 cylinder crankshaft which now needs the bearings machining .
      I am struggling to get a nice finish due to 'chatter' at the tool tip. I have adjusted the jibs on the cross slide so they are a little tight and set the tool to centre height.
      What would you suggest the best way to grind the tip of my Hss tool to be able to take light cuts , left and right , and keep the bearing parallel.
      David K
        @davidk77137
        #388738
        Nick Hughes
          @nickhughes97026
          Relieve the centre of the tool, as shown in the first 3 min of this video:- **LINK**
          Edited By Nick Hughes on 01/01/2019 19:36:07
          #388741
            I tend to use a knife tool to go down each side of the webs and take as much out the middle as possible with that then change to an indexable parting tool for which I keep an insert that has had the middle ground away with a Dremel cutting disc to a similar profile to that in Nicks video. HSS would look like this
            #388743
            AJW
              @ajw
              Amazing how all our ‘roughing’ cuts come finished well then when we get to the ones that matter it goes downhill!
              Alan
              #388745
              David K
                @davidk77137
                What is the best way to grind the rounded edges , I have some diamond files so I could do it by hand / eye with the files.
                The bearing is only .437 inch wide so the tool is quite narrow .
                #388746
                duncan webster 1
                  @duncanwebster1
                  I've used a diamond file to shape tool to Jason's profile. It's slower than a Dremel, but more controllable
                  #388747
                    Yes, just stone the corners round so you leave a small fillet in the corners.
                    #388751
                    FMES
                      @fmes
                      Posted by JasonB on 01/01/2019 19:59:25:
                      Agree with Jason, but I finish to size with a shaped grinding wheel.
                      Edited By FMES on 01/01/2019 20:27:34
                      #390529
                      David K
                        @davidk77137
                        Well the crank has not gone well. I ground a form tool as described and cut the four big ends first.
                        I achieved a nice finish with the lathe and then just ran some wet/dry around to polish the bearing.
                        Then I set up for the Mains , no matter how I tried I suffered vibration and a poor finish.
                        I tried adjusting tool height, different speeds , re grinding tool bits, ect but could not get the finish I achieved with the Big ends. I am now at the stage were I do not have enough material left to risk another bad cut so I am going to make up grinding wheel and see if I can save it by grinding down to size.
                        I am thinking the problem may be from cutting the Webs and Big ends first , weakening the crank and causing it to flex [vibrate]
                        Edited By David Kenyon 2 on 11/01/2019 13:20:25
                        #390532
                          Did you put packers between the webs so it would not flex when tightening the tailstock?
                          #390542
                          David K
                            @davidk77137
                            Yes , I made some aluminium packers , I also tried replacing the revolving steady with a fixed and various amounts of pressure from the tailstock. Its been very frustrating , especially as the big ends came out so nice.
                            #390548
                            Roger B
                              @rogerb61624
                              Is the crankshaft cut from solid or a casting?
                              Are you doing all the turning between centers?
                              Is it possible to support one end in a 4 jaw chuck to improve ridigity?
                              #390600
                              David K
                                @davidk77137
                                The crank was cut from EN8 round bar and turned between centres.
                                I could have used a 4 jaw but that option is gone now really as I don't want to risk it.
                                On the plus side I have wanted a tool grinder for a while so now I will get on with making one.
