You could try a variable regulator with propane or butane, with the existing jet, and see what you get, I have a flamefast brazing hearth, the older round type and will be doing this very job as well, mine has a blue gas hose. so I assume it is for NG, so the existing jet will be too big, I have used a spare flamefast torch with compressed air and propane, and the flame is very long and large (I call it "the blowlamp of doom"
but controlable using a regulator and the torch controls. Remember, the torch controls vary the volume of gas, not the pressure so you will need a regulator as well. Most domestic gas hobs come with two sets of jets, one for NG and one for propane, so that could be the place to start, as there will be at least four different sized jets in the propane conversion pack that comes with the hob. Hope this helps, let the group know how you get on.
Phil
